20 Most Recent Hotpoint VBXR1090B Top Load Washer Questions & Answers
Will not agitate but spins
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
4/7/2012 5:42:38 AM • Hotpoint... • Answered on Apr 07, 2012
Washing machine will not spin
Is the wash load unbalanced also to check the drain for blockages and if the lid switch works ok hope this helps.
1/8/2012 3:00:49 PM • Hotpoint... • Answered on Jan 08, 2012
Cold water inlet flow is low and constant. do i
Hi, Yes....
If you have a problem with your washeror dishwasher continuing to fillwith water after the valve has closed, then you this tip will help youunderstand why that is happening.
Here is a tip that will help you...
Washer orDishwasher Fills with Water when off
heatman101
9/5/2011 7:03:45 PM • Hotpoint... • Answered on Sep 05, 2011
Very noisy spin cycle
Not a good sign, do you see any water under the washer after a load is completed. How do you tell when empty tilt it back a ways and check it, if it does it could be a leaking tub seal and a replacement may soon be in order. Unless you overhaul it.
4/2/2011 5:41:47 PM • Hotpoint... • Answered on Apr 02, 2011
How to remove front panel
What you do is align a thin blade putty knifes with the edge of the lidand find the clips. Press downward to release the front panel.themobilian_1855.jpg
Training manual
themobilian_1856.jpg If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
3/12/2011 5:13:20 PM • Hotpoint... • Answered on Mar 12, 2011
Will not agitate or spin
Have you checked the basket drive?
2/23/2011 8:27:42 PM • Hotpoint... • Answered on Feb 23, 2011
Topload washing it cannot start, what is the
Hello there :
whenever you have this type of problem you first need to ensure that you are getting power to the machine if you have power to the machine the next step is seeing if the lid switch is working this is done by opening the lid and inserting a knife or a small long object into the slot that the switch is located and press in on it when the machine is turned on to the first wash cycle or even the spin cycle you should hear a click sound but if no sound then you will need to have the switch checked out and probably replaced this is the most common part that fails on these machines,
some of these machines have a small fuse that controles the starting and stopping of the machine so if this is blown than this would need to be replaced it may be located on the controle panel where the buttons are at or the touchpad is ok
So check all of these out for me and let me know what you have found i can assist you further if needed to help test and remove and install parts ok?
Hope this helps
Best regards Michael
2/23/2011 6:36:52 AM • Hotpoint... • Answered on Feb 23, 2011
Hotpoint washing machine model vbxr1090b2ww
Here are some solutions.
Hope this helps you...Jim...Please leave a comment...Thanks!
LEAKS ALL THE TIME Is your GE washer leaking all the time, even when not in use? If so the problem is the fill hoses or the valve. Look behind the washer to see if water is coming from the hoses. If not, take the cover off to the control panel. Once off, you should see if the water valve and if there is leakage - it needs replacing (if it is leaking). This is the most popular water valve for GE top-loading washers made after 1995 and the part number is WH13X86 Order Here. show?id=6bjnatppuce&bids=92089.1&type=10. Note that some models have a water valve with more than two coils. In this case, you will need to order the valve by model number at AppliancePartsPros.comshow?id=6bjnatppuce&bids=92089.10000015&type=3&subid=0 Buy Fill Hoses Here. show?id=6bjnatppuce&bids=92089.1&type=10
LEAKS DURING FILL CYCLE Is your GE washer leaking during the fill cycle? If so the problem may be in the valve. Follow instructions above, only this time start the fill cycle before looking at the valve.
If your washer overflows with water during fill cycle your problem is the water level control or the water valve. If you must cut the water off from the house plumbing to stop the water then there is no need for testing, just replace the water valve. First, you need to turn on the washer. The washer should start to fill with water, now cut the washer off and on repeatedly (note to yourself whether the water turned off every time). If it does cut off every time you cut the washer off, then it's most likely in the water level control. If it keeps running after you cut the washer off then, the water valve is bad and needs replacing. (Note that the valve can stick intermittently so it still may be bad if it passed the test) Water valves can be purchased at AppliancePartsPros.comshow?id=6bjnatppuce&bids=92089.10000015&type=3&subid=0
If the water valve doesn't stick in the first test then you need to check the water level control. First, remove the front of washer (insert butter knife between the top and the front pushing on the clips) then look on the side of the tub and you should see a tube attached to a box. Remove the tube (make sure all the water is out of the tub) look in the tube to see if is stopped up. Often it will stop up near the end. If it is, you can clean it out with a toothpick. Once it's clean, reinstall it and your washer is fixed. If the tube is not stopped up reinstall the tube. Now set the water level control on the lowest setting and start filling the washer with water. If the water stops when the tub is approximately half full (this varies with every model) turn it up to the next level (you may have to reset it). Repeat until the tub is full. If at any the water level gets above the last row of holes in the tub, unplug the washer. If the water stops running when you unplug the washer, replace the water level control. If the water doesn't stop, turn the water off at the wall then replace water valve. Water level contorls and water valves can be purchased at AppliancePartsPros.comshow?id=6bjnatppuce&bids=92089.10000015&type=3&subid=0 . LEAKS DURING WASH Is your GE washer leaking during wash? If so the problem is the tub seal (seals around the transmission where it goes through the tub), drain hoses (including the tub to pump hose) or the pump. First take the front off the washer (insert butter knife between the top and the front, pushing on the clips) then start the fill cycle. Now start watching until you see a leak. If the leak is coming from the tub seal, the transmission needs to be replaced (note that changing the transmission is expensive and takes special tools, so you may consider replacing the washer). If the leak is coming from the drain hose or the pump you need to replace it. If you don't see it leak at all, your soap may be the problem. To check this fill the washer with water and the amount of soap you normally would use. Then start the washer and watch the tube coming from the left back of the tub (the overflow pipe). If soapsuds come out of the overflow pipe then try cutting down on your soap or switch to another brand. This may fix your problem. These parts can be purchased at AppliancePartsPros.comshow?id=6bjnatppuce&bids=92089.10000015&type=3&subid=0
LEAKS DURING PUMP OUT Is your GE washer leaking during pump out? If so the first thing you should look at is the drainpipe (to your house plumbing). Fill the washer with water, and then turn it to spin and start it. Now while it's pumping, look at your drainpipe if water backs out (it may not back unless you have soap in the tub), then the problem is in your plumbing. If it doesn't, follow the same steps as above in "leaks during wash." Only this time watch for leaks during pump out as well.
2/13/2011 2:47:04 AM • Hotpoint... • Answered on Feb 13, 2011
The machine will not move thru the cycle
Greetings,
check for soap scum build up inside the pressure hose right where it connects on the outer tub. I would then advance your water level switch to different settings to see if this makes a difference. if it does, then this may be the problem..i do have a question..does it ever overflow onto the floor, or does the washer drain pump come on and drain it...
1/28/2011 3:44:27 PM • Hotpoint... • Answered on Jan 28, 2011
How to remove agitator
grab at bottom base and pull hard upward
1/27/2011 3:28:27 AM • Hotpoint... • Answered on Jan 27, 2011
Cycle selector knob will not start at where i
There is a clip that holds the knob on. If you can't pull the knob off, then the clip is good and you will need to replace the knob. Here is a link to the part.
1/26/2011 11:11:49 AM • Hotpoint... • Answered on Jan 26, 2011
My washer will run the was cycle, but when it gets
most likely you could have a bad pump or it's clogged with something.with a shop vac vac out all the water out of the tub,then remove the front panel with a putty knife and with a pair of pliers remove the hoses off the pump,try to wiggle the hose so the water drains out slowly and you can vac it up as it leaks out,clean out the pump and check the hoses.put some water in the machine not to much in case the pump is bad,you might have to drain the water again but hopefully whatever you remove out of the pump it will still drain and you won't need a new pump.if it works great if not change out the pump part number WH23X10013 and it's around 40 to 50 dollars.let me know how you make out
1/14/2011 12:20:45 PM • Hotpoint... • Answered on Jan 14, 2011
Spinning slow and a burning smell
needs main belt tightened or replaced,adrian,,,,
12/3/2010 1:59:42 AM • Hotpoint... • Answered on Dec 03, 2010
2answers
The washer is working ,but the wash cycles even on
Your timer must be on the way out. You could try to oil it. To get it out you need to use some tweasers to remove the knob retainer:05a9706.jpg If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
10/28/2010 3:05:14 PM • Hotpoint... • Answered on Oct 28, 2010
VBXR1090B WASHER DOESNT SPIN BUT WILL PUT RINSE
if the machine basically stops after the wash cycle, but prior to the rinse/spin cycle and won't do anything, yet when you move the timer into the rinse cycle it will fill with water as per normal, and again when it hits spin it stops.. then you have a bad lid switch, the lid switch can be accessed by sliding a putty knife between the top and front of the unit about 2 or 3 inches in from the corners and pushing in, there are hidden spring releases there that will allow you to pull the top of the front panel out, then lift if off its supports on the bottom, the top of the unit that has the lid switch can be raised by removing several screws from the brackets of the top. the part number for the lid switch is WH12X1043 $16 - $29..
good luck, have fun.
8/4/2010 12:38:35 AM • Hotpoint... • Answered on Aug 04, 2010
VBXR1090BOWW The agitator barely moves. Shortly
www.seiaarons.com/GE%20VBXR1090DCC.pdf
http://www.acmehowto.com/howto/appliance/washer/washer.php
It sounds like you may have a faulty motor or drive? You will have to perform the troubleshooting steps in the manual, to check, there is an inspection panel, on the machine, remove the fastenings and look inside there should be a maintenance Sheet, this will help you isolate your problem. Of course if you cannot or do not wish to do it, then I recommend a professional be engaged, always ask for a "Quote" before proceeding with any repair.
6/15/2010 3:09:36 AM • Hotpoint... • Answered on Jun 15, 2010
Hotpoint VBXR1090B Top Load Washer Logo
52 questions posted
Top Hotpoint Washing Machines Experts
vince
Paul Carew
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Hotpoint Washing Machines
Most Popular Question
remove front panel
  • Washing Machines
