20 Most Recent
LG VX3100 Questions & Answers
Forgot lock code for lg
hi..
To lock the phone:
- Press the left soft key for Menu.
- Select Settings then press OK.
- Select Security then press OK.
- When prompted, enter the 4-digit lock code (the default code is the last four digits of the cell phone number).
- Select Lock Mode then press OK.
- Choose your preferred option then press OK:
To unlock the phone:
- Press the right soft key for Unlock.
thanks for rating
6/2/2011 6:13:25 PM •
LG VX3100
Answered
on Jun 02, 2011
Forgot the lock code to
Hi,all you need now is an unlock,and that could easily be done by visiting a mobile phone software repair man to help you wit the flashing of your phone with the use of internet and cords.Goodluck,Take care.
6/2/2011 5:55:08 PM •
LG VX3100
Answered
on Jun 02, 2011
LG GC900 stuck on silent
Hi
Since you have done all the necessary checks and the phone still stays on silent, then the problem is from the speaker which is where ring tones come out from when you receive a call or text message
The solution is to have the speaker replaced because it is no longer working. A repairer can help you replace it if you cant do it yourself.
Cheers
3/11/2010 11:56:35 AM •
LG VX3100
Answered
on Mar 11, 2010
I have forgot my password, I do I find it?
well, what i recomment to do is take it to your closest cell phone place. its going to be difficult to try and do it yourself. so I recommend doing that. believe me it has happend to me
11/18/2009 2:13:40 PM •
LG VX3100
Answered
on Nov 18, 2009
Lg Trac Phone
Usually if you have not set a lock code on your phone, then it is preset to the last 4 digits of your phone number. Give that a try.
2/15/2009 10:12:52 PM •
LG VX3100
Answered
on Feb 15, 2009
Phone does not work properly
Since cellphones have ways of indicating water damage (internally AND externally), warranty service is pretty much out of the question. You can TRY using a blowdryer (on LOW heat) to make sure the insides of the phone are dry, and put the battery back in to see if works.
Incidently, the lithium-ion batteries in cellphones are potentially dangerous; anything that might short them out, like physical damage, water inside, could cause them to catch fire and burn like a flare! Also, you don't want to get them too hot, say over 140 degrees F-same result.
9/4/2008 5:32:18 AM •
LG VX3100
Answered
on Sep 04, 2008
LG phone
Buried in the phone settings, there will be an option to select the service provider manually or automatically.
First port of call is to see if this has been inadvertantly set manually to a "foreign" provider. If it has, then changing it to Auto should sort you out.
If it's in auto, but still misbehaving, then try selecting your own provider manually.
A.
2/2/2007 12:34:35 AM •
LG VX3100
Answered
on Feb 02, 2007
How come my LG Env3 only displays the Verizon logo?
There are a few possible reasons why your LG Env3 is only displaying the Verizon logo:
- The phone is stuck in a boot loop: This can happen if the phone's software becomes corrupt, causing the phone to continuously reboot and display the Verizon logo.
- The phone is stuck in a firmware update: If the phone was in the middle of a firmware update and the update failed, it may be stuck in a loop and only display the Verizon logo.
- The phone has a hardware issue: If the phone's hardware has become damaged or malfunctioning, it may only be able to display the Verizon logo.
- The phone is locked: If the phone is locked with a passcode or pattern and you've tried to enter it multiple times, it may display the Verizon logo.
If you're unable to fix the problem by yourself, the best solution would be to contact the manufacturer or the carrier to get the phone checked.
It is also possible that the phone was previously owned by someone else, it may be locked to a carrier and the only option is to contact the carrier and ask for assistance
