20 Most Recent
Nokia 3585 Questions & Answers
Nokia 3585 security code lost
Check out this link below to download a PDF manual, software, and more for your phone. Just copy and paste into your browser.
http://www.nokiausa.com/get-support-and-software/product-support/nokia-3585
SECURITY CODE from page 54 of your manual:
Your phone prompts you for a five-digit security code for certain features and commands.
Access is granted only after the correct security code has been entered successfully.
The default security code is 12345. It is recommended that you change this code at once,
write it down, and store it in a safe place away from your phone.
Important: When entering your security code, ***** is displayed on the screen to
keep others from viewing your code.
You can delete the last entered digit by pressing Clear (or by pressing and holding Clear to
delete all the digits more quickly). Enter the correct code or press Back to exit. If you enter an
incorrect security code (Code error will appear) five times in a row, your phone won’t accept
any entries for the next five minutes.
Change your security code
1 Press Menu 4-5-2-4 (Settings > Security settings > Access codes > Change security code)
and press Select.
2 Enter existing (or default) security code and press OK.
Security and System settings
3 Enter new five-digit security code and press OK.
4 Re-enter your new five-digit security code for verification, then press OK.
Your phone displays the confirmation message Security code changed.
Important: If you change your security code and don’t remember the new code,
contact your service provider. Once you change your security code, the default code
is no longer valid.
Hope this helps, let me know if I can help you with anything else. It would be very kind of you if this does work for you to please rate me or leave a short note. I would really appreciate it. Thank you for your time.
JimmyC
11/4/2009 11:37:35 AM •
Nokia 3585
Answered
on Nov 04, 2009
Restriction code for Nokia 2690
It is normally recommended you Don't post your IMEI on websites. It is a security code for that phone.
Usually the IMEI number has to be reset by your network provider. It normally cannot be done directly from the handset. Did the handset accept the new sim card. Some handsets can be locked to a specific network and changing network can stop your phone from working.
Nokia 2730C-1. can I unlock the network
If the phone was not used 2012, the phone number and phone have been deactivated from the network you used to pay for service. You need to set up a new contract as they expire after about 2 years of inactivity.
Backup contacts from broken nokia 2730c-1
Yes, there is a solution to backup contacts from your broken Nokia 2730c-1.
Before flashing the phone, one option is to try using Nokia Suite software on your computer to connect to the phone and backup the contacts. Another option is to remove the SIM card from the phone and insert it into a different phone to access and backup the contacts. You can also try using third-party software or services that specialize in extracting data from broken phones. It's important to act quickly to ensure you don't lose any important numbers. Good luck!
