20 Most Recent
Sanyo PM-8200 Questions & Answers
My sanyo pm 8200 wont hold charge!
Since the battery and charger are new and yet it does not still hold charge.
Have put the battery in another similar phone and try to charge with your charger to see if it will hold charge? if you have.
It means the charging port of your phone is bad and you will need to replace it.
The charger is not charging the battery in anyway because the charging port is bad, so just change your charging port, your phone will now hold charge.
Take care.
Need copy of owners manual
It is a simple question and does not need the assistance of a technical expert.
Where can we get a copy of the owners manual?
Phone won't charge
First we would need to know what phone you have and the carrier. Some phones do not have desk top chargers for batteries and the only thing that could be done is a fix by the Warranty repair office. If you have the warranty or pay the fee for the warranty with your carrier, call the Carrier and ask for the Warranty repair office number or take it to a repair office if you do.. Most warranty repair office can fix the phone at the site (again this depends on their process)
Sanyo pm 8200 picture mail
I had the same issue once I scrolled down from the picture and found the picture mail had an option to view messege.
If that is not the case could be a programming error with your picture mail. You might want to contact your carrier for support issues.
Won't turn on
Sounds like you both need to contact your carrier for the repair office phone number. Sometimes the carriers can reset the phone for a fix, sometimes the phone needs more detail attention that a repair office could help with,.
Sanyo 8200
Call your carrier for assistance. usually it is the last 4 digits of your phone number. However, if somebody has set a code on it... you might be able to go online to retrieve the info. I would FIRST call your carrier they may have a simple fix.
Delete
You need to go to each option, ie pictures go to camera then pictures on phone and check mark each one then select delete.
sane for Messeging textes There should be an option to delete all messgege.
Phone books vary you might be able to delete all phone book info at the same time or you may have to go to each entry to delet them.
Sanyo pm 8200 sprint service no signal
Not sure about the bars, but you can go to the settings in the main menue and try to go to roam only. It could be that you r carrier is having a problem with their tower. Your phone, normally, will try to stay on your carriers towers. If you force it to a roaming status, you might get a better signal, but on a roaming network.
j
Sanyo-8200
Okay, if it is not holding a charge you need to take that phone AND the charger into a store and have them run a diagnostic to find out what the real problem is.
