20 Most Recent
HP Compaq FS 7550 17" CRT Monitor Questions & Answers
Screen Adjustment
On your monitor at the bottom there is 3 buttons. The one all the way to the left is the "menu" button. The next one (going right) is the "NEGATIVE" button. The next one (going right) is the "POSITIVE" button.
You can move your screen around. First, start by pressing the menu button.Then, a menu in blue, with a bunch of little white icons will appear. Next, go over two icons by pressing the positive button twice. Then, proceed to push in the "menu" button again. A bar will appear. By pressing your negative button, your screen will move left. Pressing your positive button will make your screen move right. Adjust your screen until the black on both sides are of even proportion. Then, press the menu button to return to the orginal menu you started at. Proceed to press your positive button two more times. Then, press your menu button. Then, once again, use your positive button, and your negative button to adjust your screen to even out the black on the top and bottom.
My monitor's image size is getting small horizontally i turn on my monitor and it get back actual after 5 minutes while it's working? and the brightness is also so much increased even my panel brightn
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they might be faulty
a computer needs its power and data to travel through every working device and to continue its cycle and to have an end so any faulty leads will end up with a computer error
also
Click start control panel administration tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers
you might have to remove your graphics card to make sure the socket is clean
restart your computer the reinstall it this should activate found new hardware wizard
if your computer came with a mother board disk the drivers could be on it
click start control panel,display,desktop you can select a different desktop from the drop down list
or a browse button where you can select different pictures this may vary depending on your operating system
also you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settingsalways click APPLY after making any changes
hope this helps you
Hi we have a compaq
You may try messing with the settings on the monitor. The menu buttons are usually on the front. Try to find something that deals with the color tones of the monitor. If messing with these settings doesn't fix your problem, then unfortunately, it is probably time to throw it out.
I have compaq 7550 computer
RMB click on the desktop and select properties from the drop down menu.
LMB click on the "Settings" tab.
Select "True colour"
Move the slider to read 1024 X 768.
Change the refresh rate to 50Hz.
This should get you back on an even keel, you should then be able to fine tune the settings to what you prefer.
Monitor becomes blue
if you hold the cable and shack it , if the colors changes there is aproblem in your cable you can cut the socket and measure the socket pins with the cable colors (there is 9 colored wires ) then buy anew socket (or give it to an expert)
Screen is getting wavy messed up i think ill
How is the screen of your monitor messing and when you reboot the system, how is the performance? hope you are satisfy with the performance now? if not, you give details of the problem, maybe, i can advice on what to do.
Take care.
What is causing my FS7550 Compaq monitor to blink
check if it's correctly pluged in to power jack. also check if the cable who connects monitor and comuter is loose. if it is, then unplug it then plug it again. do that for the power jack. if the monitor does that when your computer is off, or hibernating, don't worry it is completly normal.
rate and comment, and thanks for using fixya
My DSL service has slowed down considerably. The
PROBABLY NOT.YOU JUST HAVE PROBLEM WITH YOUR MONITOR AND NOT WITH CPU.TALKING ABOUT SLOW SPEEDS YOU JUST NEED RO INSTALL REGISTRY REPAIR SOFTWARE JUST DOWNLOAD IOLO SYSTEM MECHANIC AND INSTALL IT ON YOUR PC. TO INCREASE CONNECTION SPEED USE MODEM BOOSTER
The screen is tilted
You can adjust the keystone of the monitor..
this will remove the trapezoidal shape and square up the image to the monitor.
Check on the monitor for the menu controls and you should be able to find the keystone adjustments... allows you to adjust the upper width, lower width, etc...
Everything was fine and the all of a sudden screen
the CRT is shorting out which is why its coming on and turning off. If you bring it to an electronics shop it will at least cost $100 assuming they can do something with the CRT. If not then it will be more and you would be better off getting an LCD monitor and they are usually around $125-$140 for a 19" on sale.
The Power Cord came loose and has been lost!
radio shack would be my starting point. if there are any computer solutions or stores in your area go in and ask em if they have a used power cord should be the same as the power cord for the tower itself.
please take a moment to rate this.
Compaq 7550 screen issues
Your monitor is having thermal problems. Some part in the horizontal circuit is changing value as it warms up, and you're seeing the effect. It's possible to troubleshoot this kind of problem by using spray chiller to cool down parts and find the culprit, but labor and parts would probably mean you're better off just replacing it. New LCD's are quite cheap today, and you'll gain extra space on your desk if you get one.
Audio Driver
You need to post the model # of your pc, as the monitor is not the problem...
