20 Most Recent HP Pavilion F1523 15" LCD Monitor Questions & Answers
Assuming that you mean that you cannot play dvd movies, you need software to play dvds.
You can download a free dvd player but you have to be careful about free software, sometimes they contain hacker tools
HP Pavilion... | Answered on Jun 25, 2019
try it with a full-wave bridge rectifier and filter capacitor (1000uf/25v)
HP Pavilion... | Answered on Dec 29, 2017
lay down face down on table,unscrew all screws in back,leave them in the back,lift the back off and replace cable
HP Pavilion... | Answered on May 21, 2015
This can happen if the minus button which happens to also be the auto image-adjust button is effectively grounded due to some internal fault or
if the switch itself has got jammed internally. In this case, if video signal is present, the motitor reproduces the image but continuously displays "adjusting" as osd message. If video signal is missing, the monitor cycles through solid colors in the black, red, green, blue, white sequence. I think this is part of the hp f1532 design to help the service
engineer( though I have not found any reference to it in official documentation yet). In this special case( minus button grounded), the
menu button is ignored by the monitor.
Kumar Talreja
HP Pavilion... | Answered on Dec 28, 2014
I have an hp media center that runs windows xp with service pack 3 and my monitor is an hpL1706 monitor and was running fine now it says no input and goes into sleep mode how do I fix it?
HP Pavilion... | Answered on Jul 31, 2014
Good day!
reasons are: defective memory, defective power supply, infected with malware and defective vga cable.
Visit HPParts us Computer Parts Power Supplies Electronics Hard Drives...
HP Pavilion... | Answered on Mar 28, 2014
Good day!
Defective cable, defective VGA device, corrupt drivers or a failing monitor.
Good day!
Right click in desktop > properties > pop up display properties > click on settings > advance > adapter > click list all modes
select the display you needed for your pc.
Have a good day!
visit HPParts us Computer Parts Power Supplies Electronics Hard Drives...
turned off , in the monitor. OSD setup.
cable fell off, (sound) or half plugged in.
sound turned own in PC or muted.
if you can't find out, why, try plugging in the monitor to another system and test it there, bingo, instant answers
HP Pavilion... | Answered on Mar 20, 2014
Some monitors have low resolution, that if it doesn't support that resolution then you'll expect an "input signal out of range" message on screen. try to boot on "safe mode" if it works then you have to lower your screen resolution at "display properties" if not then the monitor has a defective data cable. ;)
HP Pavilion... | Answered on Aug 09, 2013
Once you realize that resetting it doesn't work (as I did ) take it apart. This instruction is for an hp w2007 only! It's the one I just fixed. Remove the three screws holding the base on. The one in the middle is hard to see because it's in a hole but readily accessible. Remove the black back cover by inserting a skinny screwdriver between it and the gray housing. Start in the middle on any of the four corners.Pry it up and work your way to the corners. At the corners pry up with more force and the plastic tabs will snap off. Trust me, just do it!! Once you have snapped the plastic tab at all four corners the back will lift right off. locate the three small wires that go into the menu, -, +, select switches. Cut the three wires and tape them off separately. Do this so they can't touch the case or each other. Do to the wires that are going back toward the monitor! The ones going to the switch do not need to be taped. The switches are now dead. Is that clear? Cut the wires going to the switch and tape the cut ends that go back to the monitor. You will no longer be able to manually adjust anything but I never used the adjustments anyhow. The PC will take care of it for you. I did this 8 hours ago and it's still working perfect! Before I made the fix I was getting OSD Lockout, no input signal, it was scrolling through the menu and the screen was going blank every 5 minutes!! It will work!!!
HP Pavilion... | Answered on Aug 12, 2012
Click f8 key continuously onrestart, from the list of options select 'best known configuration' and clickenter, wait the system to load normally.Hope this helps, pls rate and comment.
HP Pavilion... | Answered on Aug 07, 2012
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure dust free connections and are not faulty
computers need power and data to travel through every working device and to continue its cycle and to have an end so any faulty leads will end up with a computer error
Click start control panel administration tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers
You might need to upgrade your graphics card drivers
you might have to remove your graphics card to make sure the socket is clean
restart your computer the reinstall it this should activate found new hardware wizard
if your computer came with a mother board disk the drivers could be on it
click start control panel,display,desktop you can select a different desktop from the drop down list
or a browse button where you can select different pictures this may vary depending on your operating system
also you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
hope this helps you
HP Pavilion... | Answered on Jan 01, 2012
Your monitor does not support the display settings you have set in your operating system.
To change these settings go: (Windows 7)
Control Panel > Display > Screen resolution [Change to 1440x900]
then on the same screen, go to Advanced Settings > Monitor > Screen Refresh Rate [Set to 60 Hertz].
(This usually happened if you switched monitors, or used a TV, or maybe a projector).
You can use the same method to set up any resolution or refresh rate you want.
HP Pavilion... | Answered on Sep 23, 2011
Check for bad caps with bulging tops/bottom seals in the power supply first, very common problem in all LCD monitors as you can see in my albums here:
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Post back what you find.
HP Pavilion... | Answered on Sep 09, 2011
HP Pavilion F1523 15" LCD Monitor Logo
96 questions posted
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Pavilion HP
  • Pavilion HP
Most Popular Question
hp l1706 monitor keeps going into sleep
  • Computers & Internet
