20 Most Recent HP Compaq 1720 (Carbon, Silver) 17" LCD Monitor Questions & Answers
Compaq 1720 monitor says out of range
Try set down the vertical frequency to 50 or 60 http://electronicshelponline.blogspot.com/
9/8/2014 6:35:19 PM • HP Compaq 1720... • Answered on Sep 08, 2014
Power cable description
Hello,The power supply is 12v. There are two different versions of that model monitor and the plug connector for the power is different. One version has 4 pins on the power connector on the other has just a center pin and barrel. You need to check the connection on the back of your monitor before you order that adapter to be sure and get the correct one that you need. You can get both type here:http://www.ccl-la.com/catalog/index.php?cPath=25
3/13/2013 9:06:47 PM • HP Compaq 1720... • Answered on Mar 13, 2013
How can i hold my LCD monitor on the wall ((copaq
make sure you have a wall-mounted rack which suits your monitor. Contact your PC dealer for details ..
10/29/2011 4:53:31 PM • HP Compaq 1720... • Answered on Oct 29, 2011
My Compaq 172 monitor won't
Failing Power capacitors. The capacitors hold the charge necessary to build up the voltage that lights the screen. When they leak or fail to hold the charge, the screen will cut out. It could also be a fault in the switch circuitry. Really needs looking at by a qualified technician.
7/21/2011 11:11:44 PM • HP Compaq 1720... • Answered on Jul 21, 2011
I need the pin-out for
There are two pairs on the connector: one pair for 12vd, one pair for Ground return.
I did not work on one of this model for a couple of years, but I use Ohm meter to find out by check for 0 Ohm between the Monitor metal chassis which is ground, tow of the four pins should read 0 Ohm, that will be the Negative, the other 2 will be +12vdc (it should read 0 Ohm between these two 12vdc pins).
Please post back what you find.
Please leave rating if it helps.
Basic LCD monitor and TV troubleshooting guide: http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide http://www.fixya.com/support/r7406380-tv_training_manuals Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you. Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
1/28/2011 4:57:05 AM • HP Compaq 1720... • Answered on Jan 28, 2011
3answers
Display HP Compaq 1720. OSD
aldo_tomazic
In regards to your issue with your monitor if you have changed out the VGA cord and tried the monitor on another computer but still have the problem this is a sign of a short in the monitor its self.
Note with modern electronics they have contact switches. What this means is means is you close the same circuit to turn a item on or off. The problem with these switches is that if there is a short that is not properly going to ground this can cause a charge to build up on the mainboard to a point where is starts turn on or off things on its own. If not fix this can damage the device more.
So you can try to take the monitor to a electronic repair shop but in most cases if maybe cheaper to replace the monitor. Another thing you can try is making sure that monitor is plugged in to a properly grounded plug. Less than 50% of house that were built over 10 years ago have properly grounded plugs. If you are not sure you can get a tester at your local hardware store. It looks like a 3 pronge plug with lights and it will let you know if the plug is grounded. Once you get the monitor plugged into a ground plug this may fix the problem for the time being.
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
1/8/2011 3:23:20 PM • HP Compaq 1720... • Answered on Jan 08, 2011
Picture wont show. It shows for a second then
Looks like a component failure in the monitor, the backlight or inverter box has problems.
Its a common fault.
11/13/2010 7:08:55 PM • HP Compaq 1720... • Answered on Nov 13, 2010
Power button doesn't work
Not very likely to be the switch itself, the switch is a tactile momentary switch, more likely to have failed power supply due to bad caps just like the rest of failed monitors here, check to see if your adapter is putting out 12vdc, then we need to find out if it is getting 12vdc all the way to the main board and the inverter board:
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
9/3/2010 4:41:20 AM • HP Compaq 1720... • Answered on Sep 03, 2010
Compaq 1720 monitor: the green
You need to find out if the power supply is still putting out 12vdc, you may have to test it with a load (use 12v car bulb such as the brake lamp). It is getting hot can be due to bad power supply or too much load because of short circuits in the monitor. Please post back what you find about the power supply first.
http://www.unitedsale.com/AC-adapter-Power-Cord-Charger-12V-35A-For-Compaq-1720-LCD-Monitor-Brand-New_p_219.html
9/3/2010 3:45:06 AM • HP Compaq 1720... • Answered on Sep 03, 2010
Contrast and Brightness require adjustment
hi im josh in cebu phils. Maureen may i help you? If it happened yesterday that the contrast box keep on coming. there's a problem in your monitor.so try to check the buttons if covered with dust cleaning may solved the problem.Maureen if you have the manual use it in adjusting the resolution and if you dont have try to press the button mark + or increase just press both of the to the brightnest as posible so that you may be able to proceed another action. thats all for now.hope i helped you.good luck.
2/26/2009 10:47:24 AM • HP Compaq 1720... • Answered on Feb 26, 2009
Best resolution
Maximum resolution for this monitor is 1280 x 1024 .
Rate this solution as fixya if the above answers your question !
thnx
AD
2/22/2009 9:28:52 AM • HP Compaq 1720... • Answered on Feb 22, 2009
Missing power cord
researched online for cord.
12/6/2008 9:11:50 PM • HP Compaq 1720... • Answered on Dec 06, 2008
2answers
Power cord
I checked your monitor and judging by the picture, it requires an specific ac adapter. see photo below to see if this is what you see:
2edb0f8.jpg I show the spare part for this ac adapter is 308573-001. it runs approx $45 on google. Hope this helps.
6/8/2008 4:48:32 AM • HP Compaq 1720... • Answered on Jun 08, 2008
Compaq 1720 Monitor
You may need an adapter plug. They come with new monitors so ask around to see if anyone has one you can borrow.
5/11/2008 8:02:36 AM • HP Compaq 1720... • Answered on May 11, 2008
Cables delmonitor 1720
You can get replacement buying at any computer stall.
4/21/2008 12:58:45 AM • HP Compaq 1720... • Answered on Apr 21, 2008
Monitor HP 1720 Part n.325113-001
Your actually thinking about it the wrong way.
Replacing the screen in LCD's is more expensive then replacing the monitor. Stupid I know, but that is how they ensure you have to keep upgrading. Same thing applies to a laptop motherboard for the same reason.
You do still have one small light at the end of the tunnel though.
Check around on eBay or similar and you maybe able to find a complete monitor with a dead power board that you can salvage the screen from. Do a search for words like Faulty, broiken, not working in the computer section.
Hope that helps. =)
4/11/2008 1:51:00 AM • HP Compaq 1720... • Answered on Apr 11, 2008
3answers
I need to know how to turn on a HP X13-04657 LAPTOP, all the lights are on but nothing on the screen.
HP X13-04657, is 2007 PC THOSE this PC has CCFL back lamp strip that is dead.Vista era PC, laptops. are hard to work with now, 17 years old.is this not a HP COMPAQ presario HP X13-04657 (wrong name!) sorry !became HP in 2002. so is HP but manuals are super hard to find now. that x13 is part of the microsoft license code vista. (so is distraction to what it is)the real name of the Laptop is and was Presario CQ61 laptop CQ61 the PC has bottom sticker that shows the real names of PCs.CQ61-219TU is real name of on CQ61, there area many different sub codes, and they are not all the same.CQ61-306AX this had CCFL (cold cathode florecent lamps) that love to fail 3 waysdead, blinks ,dime or yellow = white.was made until 2009 and evolved, to LED backlamps.-410 is CCFLI will answer for CCFL as those just love to fail,but the the test is so easynow the answer for ANY laptop this old. 2007 and older. black screen all the time, and BIOS screens dead, answers only me. here. remove the main battery (large) it simply snaps off the bottom.the power pack is next we run the PC on your power pack AC to DC it must make the screen glow with something, do not use the wrong pack as in mixed up with others.now the lap top seems on, even the fan blows, LED glowpoint a flash lamp at the screen ,dark' room , and of you see any kind of LCD data on the screenthe CCFL lamp below #1 is bad.this is phase 1 testing, as other things can fail too. The keyword below is Mercurythis tells me it is those pesky CCFL glow tubes. 2007 is the year some PC went to LED back lamps. yes I was correct the service manual I did find proves they made both lamp types ccfl-hp07-psnmcz4s4yabbrmds04n13cd-d-0.jpg
4/17/2024 12:37:57 PM • HP Computers &... • Answered 13 hours ago
Dove posso scaricare il driver per HP ScanJet 8270? ente compatibile per windows 10...
Question edited for clarity. Question translated to English. We only speak English on this North American website. https://www.google.com/search?q=hp+scanjet+8270+driver+windows+10
HP Scanjet 8270 Document Flatbed Scanner
Hewlett-Packard https://support.hp.com > ca-en > drivers > hp-scanjet-827... Download the latest drivers, firmware, and software for your HP Scanjet 8270 Document Flatbed Scanner ... drivers free of cost for Windows and Mac ... Windows 10 / ...
Hewlett-Packard https://support.hp.com > ee-en > drivers > hp-scanjet-827... Download the latest drivers, firmware, and software for your HP Scanjet 8270 Document Flatbed Scanner. This is HP's official website to download the correct ...
HP Scanjet 8270 Document Flatbed Scanner drivers - Download
Softonic https://hp-scanjet-8270-document-flatbed-scanner-drivers.en.softonic.com Download the latest and official version of drivers for HP Scanjet 8270 Document Flatbed Scanner. This driver package is available for 32 and 64 bit PCs. It is ...
HP Scanjet 8270 Document Flatbed Scanner drivers - Free ...
Download.it https://hp-scanjet-8270-document-flatbed-scanner-drivers.en.download.it Download HP Scanjet 8270 Document Flatbed Scanner drivers varies-with-device. Software drivers for the 8270 flatbed model of the HP Scanjet printer. ..
4/10/2024 8:38:39 PM • HP Computers &... • Answered on Apr 10, 2024
HP Compaq 1720 (Carbon, Silver) 17" LCD Monitor Logo
21 questions posted
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • HP Computers & Internet
Most Popular Question
need pin out
  • Computers & Internet
