20 Most Recent
HP mx705 17" CRT Monitor Questions & Answers
My monitor turns yellow
Computer monitors get separate red, green and blue video signals from the computer, and if you lose the blue the result is a yellow picture. This can be caused by video card failure in the computer (very unlikely), a bad cable (fairly common), or trouble in the monitor (which is most likely what you have).
The usual problem with monitors is bad solder connections to the red, green and blue output devices. These are usually three separate transistors, but sometimes an integrated circuit that puts all three in one package is used. These outputs get pretty hot, and the heat can cause the connections on the circuit board to crack. Resoldering them usually fixes the trouble. (Sometimes the part actually fails, but bad connections are more common.)
The parts are normally in one of two places. Most commonly they are on the small circuit board you'll find right at the neck of the picture tube. Some monitors have them on the main circuit board. They may be mounted to metal heat sinks to help keep them cool. If you can identify them and resolder the connections, you'll probably get your normal picture back.
Im getting a greyish white horizontal lines in my
May be the horizontal circuits may have a component that has changed it's value due to stress and heat...you can try another monitor to rule out the computer...but from what you describe it definitely sound like the monitor
The screen doesn't show the
your screen resolution must be changed to a lower MHz...
go to Control Panel/Dislay/Display properties/Settings/Screen Resolution/
here try a lower/higher resolution
then else try Advanced option there and set a lower setting there under the General Tab and Monitor Tabs.....
some hit and trial may solve th issue...be sure NOT to chose the wrong setting as that may cause hard to your monitor
On screen display keeps appearing on, and usually
hi..i think you have a problem the CPU/Computer that's whystays on screen for so long.1st step check the IDE cable connection form the mother board to Hard Drive and 2nd check the memory or check all hardware`s.Good Luck and Have a nice day
Monitor has power light on but screen is
The picture board on your monitor is bad, since the power led or button is on, it means the
board of your monitor has developed fault.
The best thing for you
to
do now is to take the monitor to a local repairer within your vicinity or any service center
to help with the replacement of the picture board
because the fault is not something you can fix yourself, in order not to
complicate issues.
Take care.
Monitor goes to standby after booting up.( Amber light)
I'm going to guess that your monitor has different imputs and maybe you aren't selecting the right one? There is usualy a button to change imputs on the monitor. If there is no signal and you've checked all the channels, the cable your using might not be functional or your monitor might be broken.
The hp mx 705 monitor was working,then it just
If the computer is attached properly and you get the flashing lights it is due to switch mode power supply being faulty, too expensive to fix I think you will find, never seems to be anything like just a fuse I'm afraid, modern worlds tells you its time for you next monitor..... do try to ensure it aint the pc by hooking laptop or something else to this unit, or hooking another monitor to your pc to be sure but I find power supply failure is normally how monitors leave this world...
HP MX705 ON MY DESKTOP JUST WENT BLACK AND
a CRT monitor just like a CRT television when it fails may still have a light on the front panel operate you probably had a catastrophic failure usually small electrolytic capacitors near the horizontal output transistor dry up an cause the transistor to fail the voltage regulator may also fail in the process
