20 Most Recent HP vs15 15"LCD Flat Panel Monitor Questions & Answers
Hp vs15x can not power
MOORE DETAILS.
3/9/2015 5:53:50 PM • HP vs15 15"LCD... • Answered on Mar 09, 2015
I nee help connecting my ps3 to my monitor hp vs15
already answered...
2/26/2015 2:30:14 AM • HP vs15 15"LCD... • Answered on Feb 26, 2015
2answers
I need Tech manuals/Schematics for LCD monitors
Hello. what is your problem with them?
12/11/2014 9:00:02 AM • HP vs15 15"LCD... • Answered on Dec 11, 2014
0answers
2answers
Monitor says no input signal going in sleep mode
TRY UNPLUGGING COMPUTER AND MONITOR AND DISCONNECTING MONITOR FROM THE BACK OF THE COMPUTER. BE SURE TO UNPLUG AND NOT TURN OFF. WAIT ONE MINUTE THEN PLUG COMPUTER BACK IN . RECONNECT MONITOR TO THE BACK OF THE COMPUTER AND PLUG IN. IF THIS WORKS, WAIT FOR NEW HARDWARE RECOGNIZED TO COME ON. FOLLOW INSTRUCTIONS, IF ANY. RESTART COMPUTER.
1/6/2013 4:35:16 PM • HP vs15 15"LCD... • Answered on Jan 06, 2013
2answers
I need to unlock my HP computer monitor
Can't see nothing on the screen
12/12/2012 3:31:38 PM • HP vs15 15"LCD... • Answered on Dec 12, 2012
2answers
HP pavilion VF15 moitor
Replace 4 dead 470uf 16v capacitors and 1 1000uf 16v capacitor on power in circuit board. worked for me.
10/2/2012 5:08:40 PM • HP vs15 15"LCD... • Answered on Oct 02, 2012
2answers
No power when u plug in an turn on HP vs15 15 in.
You need thin flat blade screw driver to crack open the case, it is almost the same as VS19, more likely to havebad caps with bulging tops, see pictures here: http://s807.photobucket.com/albums/yy352/budm/HP%20VS19D/
4/27/2012 1:32:21 PM • HP vs15 15"LCD... • Answered on Apr 27, 2012
My hp vs 15 displays vertical color stripes that alternate different colors wether its hooked up tp computer or not what is wrong, is it junk
It may sound strange but be absolutely sure the cable is plugged into the monitor. Adapter on the computer. The serial adapter on the back looks just like video. Video actually has a faintly noticeable monitor icon rigtht next to it. Plugging into a serial can eventually blow out your monitor. Also, a.badcable can do the same thing. And if you have messed up the monitor's settings you will see the same
4/14/2012 6:25:04 PM • HP vs15 15"LCD... • Answered on Apr 14, 2012
My monitor work with another
The refresh rate of the hp pavilion needs to be adjusted to match that of the other PC then it will work.I have witten a tip on adjsuting refresh rates if you need help: http://www.fixya.com/support/r9352855-adjust_or_change_monitors_refresh_rate~ Slasher_X
9/26/2011 5:39:34 PM • HP vs15 15"LCD... • Answered on Sep 26, 2011
My Hp vs 15 lcd
If you have electronics experience then you can troubleshoot it and repair it if you don't have any experience soldering electronics I would recommend attempting a repair. Most likely it is a bad capacitor I would visually inspect them.
thank you,
Lee
7/15/2011 9:04:51 AM • HP vs15 15"LCD... • Answered on Jul 15, 2011
I can not change the
you need to change the res on the computer then it will change on the monitor
4/3/2011 9:42:43 PM • HP vs15 15"LCD... • Answered on Apr 03, 2011
My monitor is not receiving power, tower turns on
Hello Check your memory and CPU.. that is the most common problems causing this.Or RAM is not in properly.Machine have dust inside(blow out with compressed air).The heat resistant grease is hard on the CPU.The fan is not seated properly.Seat it properly.
3/3/2011 1:39:06 PM • HP vs15 15"LCD... • Answered on Mar 03, 2011
I HAVE AN HP VS15 FLAT SCREEN PANEL BUT I NEED TO
You need a audio cable with mini-stereo phone plug at both ends, see the picture.
You can get it at Radio Shack or Office depot.
http://www.officedepot.com/a/products/247878/Cables-To-Go-Stereo-Audio-Cable/?cm_mmc=Mercent-_-Google-_-Networking_and_Cables-_-247878&mr:trackingCode=356F0179-71F3-DF11-887D-0019B9C043EB&mr:referralID=NA
One end goes into the Green jack on the monitor, the other end goes into the green jack aduio line out on the PC.
Please leave rating if it helps.
1/21/2011 4:07:42 AM • HP vs15 15"LCD... • Answered on Jan 21, 2011
My computer is on but the monitor is not working.
Lok for bad caps with dome tops.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on: Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed HP monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/ Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide: http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide http://www.fixya.com/support/r7406380-tv_training_manuals Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series. Please leave rating if it helps.
1/18/2011 5:17:32 AM • HP vs15 15"LCD... • Answered on Jan 18, 2011
MONITOR WORKS ON HEATING I have a HP vs15 lcd
When the bad caps (not completely gone but have high ESR) will start working when heated up, the ESR goes down, that is one of the trick I have been using for 30 years to locate bad caps by heting them with hair dryer.
I am surprised that 3 shops cannot find and fix the problem.
As you can see in my albums, most failure are due to bad caps. Can you poat the pictures of the board?
1/15/2011 5:54:19 AM • HP vs15 15"LCD... • Answered on Jan 15, 2011
HP vs15 15"LCD Flat Panel Monitor Logo
147 questions posted
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • HP Computers & Internet
Most Popular Question
install monitor sound
  • Computers & Internet
