20 Most Recent Hotpoint NLL113EYWO Electric Dryer Questions & Answers
first check to see if you can manually turn the drum ..then go to back of dryer in the center their is a cover plate...remove 2 screws to see the drum shaft ...remove the snap ring to remove the 2metal washers..and 1 fiber washer ..their should be a fiber sleave/bearing that slides onto the shaft that is in a metal bracket ...this is the rear support for the drum ..its prob.. out of bracket an grinding a big er hole ///or the front of the dryer drum slides are bad ..if you did the belt they are on top of the front panel of the dryer door they are plastic slides ..the inside of the drum has to be ontop of them to rotate ....let me know an good luck.../joe/
Hotpoint... | Answered on Apr 13, 2013
You will need to replace the drum felt and the drum slides on the unit.
Here is the felt to order.
Here is the slides to order.
Hotpoint... | Answered on Dec 06, 2012
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Hotpoint... | Answered on Sep 01, 2011
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Hotpoint... | Answered on Aug 05, 2011
it is the door latch/switch
Hotpoint... | Answered on Feb 25, 2011
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Hotpoint... | Answered on Jan 04, 2011
your dryer vent could possibly be stopped up also you will need to have the thermistor and t-stat changed but make sure the dryer vent that goes out is not clogged. the more hot air out the better the dryer works.
Hotpoint... | Answered on Dec 17, 2010
It's either the timer switch or the motor.
Hotpoint... | Answered on Nov 26, 2010
Beyond checking for a blown fuse or tripped circuit breaker (find the dryer circuit breaker and turn it off, then back on) I would suggest having a qualified Service Technician look at your dryer. Your dryer operates on 240VAC. One leg of power (L-1, 120VAC) operates the motor and timer. The second leg (L-2, 120VAC) ends up at one side of your heating element while L-1 is on the other side. L-2 goes from your power cord to the juction block, to the motor centrifugal switch and finally to one connection of the heater. L-1 goes from your power cord to the junction block, then through the operationg thermostat and the high limit thermoastat, then possibly a thermal fuse and finally to the other connection on the heating element. L-1 and L-2 together supply 240VAC. No heat at all can be a fault with ANY of the components mentioned.
Hotpoint... | Answered on Nov 18, 2010
the old G/E style dryers never did show the time why ?that i dont know .but i believe the first or longest setting on the dial is 45 mins the only way to find out exact is to use a clock to see how long it really is ...each an every different cycle on the dial ..its a pain but you will know ...i have worked on hundreds of these ? you will figure it out ...let me know.. an good luck.. /joe/
Hotpoint... | Answered on Aug 31, 2010
is the drum spinning easy ?with no metal to metal grinding sound ? could be the start run capacitor for the motor its black/ round and is on the side of motor //or the motor windings have overheated 2 manny times an swelled the windings ///the drum shaft sleave/bearing could be wore out or gone //the front drum slides could be wore out or gone //kinda need a little more info.. hope this helps.. let me know., an good luck
Rough handling may have the drum belt to get binded. Try turning the drum by hand to see if it turns free or is locked. This may align the belt to the motor or may just take off the belt altogether from the motor. You will have to get inside access to see whats up. Once inside realign the belt to the motor and pulley assembly. Then CHECK ALSO that no wire connections inside came apart during moving. Good luck
Hotpoint... | Answered on Jul 11, 2010
There are a number of things that can cause an electric dryer not to heat...
Check out this tip that I wrote about that...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Hotpoint... | Answered on Apr 05, 2010
you could have a defective start switch on the dryer motor, bad motor bearing making motor drag and draw excessive current or a heater element shorted to the dryer case
Hotpoint... | Answered on Oct 18, 2009
get a belt with diagram on bag
thumbs up
Hotpoint... | Answered on Aug 17, 2009
Open the door. Remove the screws inside the top of the door frame to raise the lid.
Hotpoint... | Answered on Jun 14, 2009
When you hold the start switch you are energizing the start winding of the motor. If the motor does not take off and run, the most likely cause is the centrifugal switch inside the dryer's motor is not being switched. It is switched by a spring loaded collar on the motor shaft which moves when the motor starts to run, and again back when it stops. Often times this collar begins to stick on older dryers. Sometimes you can free it up by cleaning the dryer motor with an air compressor and hitting the collar with some spray lube. This only works some times. The only sure fix is to replace the motor, which unfortunately is rather expensive and a fair amount of work. Please don't bother rating this, as anything but a Fix-Ya lowers my score.
Hotpoint... | Answered on Jan 12, 2009
Hotpoint NLL113EYWO Electric Dryer Logo
40 questions posted
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
jimorris77
Archie Ferrarini
Archie Ferrarini
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
View Most Popular
Hotpoint Dryers
  • Hotpoint Dryers
Most Popular Question
dryer runs but only heats sometimes
  • Dryers
