Hi
While sliding the old belt off of the drum and pulleys loop one end of the new belt around the drum. Adjust the belt so it fits into the middle of the belt groove.Now Position the other end of the belt around the motor pulley. Pull the idler pulley toward you. Position the belt along the groove of the idler pulley. Release the idler pulley to make the belt tight.
Please check the bellow instruction for more details.
First unplug the electrical cord before replacing the dryer belt.Pull open the dryer door and locate the screws underneath the top lip that secure the top of the dryer.
Unfasten the screws holding the top on with a screwdriver and lift the top, flipping it back and resting it on the hinges.Unfasten the holding the front panel on the cabinet, using a screwdriver. These screws are at the top on the inside of the panel.Disconnect the door switch wires on the back of the front panel by hand, pulling the connector straight out off the electrical prongs and setting the front panel aside.
Locate the idler arm pulley next to the motor on the bottom of the cabinet near the back and push the idler arm forward to relieve the tension on the old belt.Remove the old belt from around the idler and motor pulleys as well as from around the dryer drum and take the belt out of the dryer cabinet.Place the new dryer belt around the drum in the center of the cabinet, fitting the belt inside the V-groove in the center of the drum, and lay the rest of the belt on the bottom of the cabinet near the idler pulley so you can access it easily.
Move the idler arm forward to allow room for the belt and thread the end of the new belt around the idler arm pulley and over the motor pulley, letting the idler arm move back to apply tension to the new belt. Check the new belt over to verify that it is lined up correctly in the V-groove on the drum and around the pulleys and that there are no twists in the belt.
Place the front panel back on the dryer cabinet, securing it with the screws on the top of the panel with a screwdriver, and plug the door switch wires back into the electrical prongs, pressing the switch wires on by hand on the back of the front panel.Lower the top of the dryer back down onto the cabinet and secure it with the screws underneath the lip of the front panel.
Plug the electrical cord of the Hotpoint dryer into the electrical outlet.
Also check this bellow links to have an in-depth knowledge related to your issue:-
http://www.ehow.com/how_5189091_replace-belt-electric-hotpoint-dryer.html
http://www.ehow.com/how_7357167_install-hotpoint-dryer-belt.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Here is a tip that will help you with changing your dryer plug.
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
heatman101
87 questions posted
195 Questions
109 Questions
28 Questions
31 Questions
25 Questions
