20 Most Recent
Compaq fs740 17" CRT Monitor Questions & Answers
Inherited Compaq FS740 but after hooking up
Check the pins on the cables. Single color presentation but clear picture indicates the pin for a particular color is borken on teh cable. Remember Red Green and Blue are mixed to make other colors. If you have predominantly one color then its due to cable not haveing all pins inserted properly or damaged.
My monitor compaq FS740 is out of focus
Focus adjustment on a CRT monitor is a simple thing to do, although you need to open the case and there are HIGH VOLTAGES inside.
The adjustment is actually on the high voltage (flyback) transformer. There are two screwdriver adjustments, the one you want is labelled Focus (of course). Do NOT adjust the other one, you may destroy your monitor and injure yourself.
This MUST be done with a plastic adjusting screwdriver, NOT with a metal one. This transformer produces in the range of 25,000 volts, from the high tension lead on the top which plugs into the back of the picture tube. This lead still has very high voltage present, days after turning off the monitor.
If you don't feel competent to do this, that's fine, take it to a technician who is comfortable with it.
You have been WARNED of the dangers.
It's also possible that the lack of focus is a symptom of something more drastic being wrong, in which case you would probably think about buying an LCD screen.
I have a compaq fs740
Hello Paul and thank you for using Fixya's services.
CRT monitors are allot like television sets. The insides include a cathode tube and a filament. Here are more details on the insides:
http://www.wisegeek.com/what-is-a-crt-monitor.htm
Being a computer tech, I was warned not to open up the CRT monitor because they have radiation, have a non-isolated line power supply and the are high voltage. This advice, I have respected as I didn't need any radiation ; )
The reason for your monitor issues is the tube. It is going out and can be replaced but the cost may outweigh the replacement. I belivee a replacement is around $69.00 depending on the size.
http://computer.howstuffworks.com/monitor7.htm
I hope I have been of some help and please let me know if you have any questions.
http://www.repairfaq.org/REPAIR/F_crtfaq.html
Computer monitor turns on but no image appears.
1. When you boot the computer keep pressed 'F' & 'J'. the display should appear if there is no hard to your hardwares.
2. If you still not get the images on monitor try to unplug and plug back in the monitor's data cord.
3. If you still do not get success then you must need to open the computer tower and see if the RAM is not loose from the slot and processor is not loose from its slot.
Once these settings are perfect nothing can stop you getting from the proper display until and unless you monitor is damaged.
Best of luck!
Compaq fs740
u need to go into your control panel then display settings to adjust rersolution
The monitor leaves a message no input signal, then " going to sle
That signal means the monitor is not getting any signal from the computer. It probably means your video card or connection is bad. You can buy a pretty cheap ($35-$100) video card from a local store (Best Buy, Circuit City, Radio Shack) or online. Since it is a newer computer you can probably buy the graphics card with the PCIe card. If you want to do it yourself you will need to open up the computer (the side) and check for the correct connection. Here is a picture to help identify the ports.
http://upload.wikimedia.org/wikipedia/commons/0/0c/PCI_und_PCIe_Slots.jpg
find the one that looks like yours and get that one. You will be able to slide off the back cover and install it. If you feel uncomfortable doing this, any local computer shop or guy should be able to help. Good Luck!
Hook up monitor speakers to PC?
how i hook up my JBL SPEAKER TO MY COMPAQ COMPUTER LOST MY DIAGRAM TO THE COMPUTER FORGOT HOW TO HOOK THE WIRE TO MY COMPUTER
Using built-in Telex mic?
There should be microphone cable that plugs in the back of the monitor to the back of the pc microphone jack. It's color coded PINK.
Compaq FS740
try pressing escape. or press f8 when your computer starts up and then press factory restore
Monitor is putting out a really annoying high tone
Sounds like you have a capacitor going bad. All monitors make a noise, whether the human ear can usually hear it or not. If it has gotten rather loud, I'm afraid your monitor is on its last leg. White is a hard color for a monitor, because the electron gun inside has to fire on all pixels, and of course black is easiest because it is just blank.
Some people I've talked to have had temporary relief or prolonged the life of their monitor by keeping it on lower resolution in order to make its job a bit easier. Besides that, there isn't too much you can do.
Removing anti virus xp 2008
try and system restore your computer to an earlier date when you knew your computer didnt have it installed
Compaq monitor
OK your monitor is failing in the Horizontal circuitry.... OR the PSU is failing to supply the correct Voltages. Either way it is probably going to fail completely soon. With monitors so cheap now, here in NZ they are about NZ$20.00 - $50.00, repair isn't adviseable to do so, it would make more sense to put the Repair monies into a NEW screen... maybe time for an LCD?
The video camera
Is it built into the monitor? If so, then there should be a USB port on the back/bottom of it or something of the sort. Are you telling me that you don't know how to connect it physically to the internet, or that you don't know how to connect it software-wise?
Monitor Problem
windows boot sector is damaged you need to reload windows from a cleaned hard drive, reformat the hard drive then install windows
Compaq Monitor
OK All these Compaq's have a Power Supply problem, or a Horizontal Voltage problem.. meaning they are on the way out. The SMPSU's in these units often fail along with the Horizontal Drive Circuitry. I think it is time for a new one? Repair of such a unint would barely be "Ecconomical" IMHO.
