20 Most Recent
Compaq TFT5015 15" LCD Monitor Questions & Answers
Dim monitor issu. I want it bright always.
it could be age-related but there is also a power setting in the OS. Alternately you can check also the monitor OSD and see if there is a setting for adaptive brightness enabled
Out of range
NO PC stated nor OS is it windows what or linux what or O/S2?
10meter . is way too long. sorry. never do that ....
10m means that. why say 10m?
lead = cable. VGA cable. it is.
VGA will not run 10meters ever, and look ok, (i do know how)
out of range means the PC is using ******* resolutions settings
on this old monitor. see list of legal resolutions below.
the answer is simple.. (NOT REALLY WITH NO PC OR OS STATED)
in your unstated PC and OS (windows)
we do what, (im blind cant see what you own)
if HP PC is get the correct driver from my PC, (GPU/VGA)
then it works.
if this pc is over 10 years old (last year made not first)
then there is no HP support.
if running XP or Vista, then Plug in play is not going to work on the dead. (MS shut this down)
so i run my scan program (pci dev maker scanner)
omg i see the video chip now, and its a XXXX
(geforce 123)
i got to nVidia and get it and it loads and works (ask how)
then in the nvidia driver i set the default resolution to
any of the BOLD max resolution's.
NO OTHERS ARE ALLOWED BUT THE BELOW OR IS OUT OF RANGE!
learn to that using a new PC using and old model
the New PC with NEW OS does not recognize this old model
its too old. now. so we must force it, in WINDOWs.
you must force your unstated video chop to the below resolutions
ranges. pick one and set it. there.
if running XP or Vista ,both are dead do PNP plug and play is dead, now. in most cases F8 safe boot , set it to say
1024x768 works then you reboot and it stays there.
but not if the driver for you VGA chip is missing or wrong.
means get it and load it now. in safe mode F8
is this pc connected to the internet as it must?
832 x 624 / 75 Hz
640 x 480 / 75 Hz
640 x 480 / 73 Hz
640 x 480 / 60 Hz
800 x 600 / 75 Hz
800 x 600 / 72 Hz
800 x 600 / 60 Hz
800 x 600 / 56 Hz
1024 x 768 / 75 Hz
1024 x 768 / 70 Hz
1024 x 768 / 60 Hz
1024 x 768 / 85 Hz
640 x 350 / 70 Hz
720 x 400 / 70 Hz
Blank screen when the cpu
Try connecting a different monitor to your computer to determine if the video card or monitor is faulty.
If the monitor is faulty then you could have a faulty inverter board or a CCFL lamp that provides the back light.
Replacement inverter board and CCFL lamps for LCD monitors are available from this WEB site.
www.lcdparts.net
Monitor stuck in sleep mode
It will do this when it's not getting a video signal from the computer. Make sure that the signal cable is firmly plugged in at both ends. Also verify that the computer is actually starting up. The monitor may not be getting a signal because the computer isn't sending any.
Monitor TFT 5015 now says "going to sleep
Make sure the laptop's external VGA port is turned on. There will be a function key somewhere on the keyboard (location varies by manufacturer and model) that controls the connector. If the connector has gotten turned off the external monitor will go to sleep because it's not getting any input.
Monitor: Compaq TFT5015 Displays vertical lines
Check that the signal cable from the computer is firmly connected and that there are no bent pins in either end. If the trouble continues, the problem is in the monitor itself. Given the low replacement cost, it's uneconomical to try repairing these.
No backlight
You may have a bad regulator or a bad mercury bulb. Testing either requires a professional with the right equipment. This area contains high frequency current. The mercury bulb is extremely delicate and has to be disposed of properly. I would suggest taking this to a pro.
How to stretch screen compaq tft5015
Right click the desktop - select graphic properties - you should have the option to stretch to fit or something like that. This could also be that your resolution doesnt match your monitor. usual wide screen monitor defaults are 1280/1024 or 1400/1068.. have a mess around and alter these - see which one fits.
Sleep mode
There is an On Display Menu (ODM). You can access it by pushing the button located on the monitor. Use +- buttons to navigate in the menu. Here you can switch off the sleep mode or change the sleep settings. I have a simular problem... I try to turn off the power save function but it seems like it dosen´t want to understand this...
