20 Most Recent Panasonic Palmcorder PV-GS14 Mini DV Digital Camcorder Questions & Answers
This error indicates a cassette mechanism malfunction.
It happens usually when you don't operate the camecorder for long time
leaving the cassette inside and the battery attached.
Solution:
1. Open the cassette housing and nock GENTLY with your finger tip
on the cassette cabinet (particularly on the position marked "push") until
the cassette is released.
2. Push on the right place (marked "push") to close and then close the
cassette housing
3. Operate the cassette (play, fast forward/backward).
Repeat the above steps several times until the problem is gone.
Advise: Remove the battery and cassette when leaving the camecorder
for long period without being operated, and store the camcorder in a
dust/humidity protected place.
Hope this can help.
Panasonic... | Answered on Dec 17, 2018
Try installing the drivers for your camera.
Panasonic... | Answered on Jul 18, 2017
you cannot move the spindles/cogs in a mini dv tape without pressing down a small lever on the rear of the cassette.
the lever is in the lower right, move the lever, then move the ribbon protector to the open position, then spin the cogs, the tape should be free.
if not, then you have a jamm inside the cassette, you can open these casettes by removing 4 small screws. ( this is a very fiddly job & you may ruin the casette, if you dont know how )
Panasonic... | Answered on May 14, 2017
The answer to this is probably in the manual - have you looked there ? If not, careful perusal of all the options in the menu system should point you in the right direction.
Panasonic... | Answered on May 08, 2017
first of all you should have your cd driver came with camcorder and as far as i know your driver isnt compatible with vista so better try to use windows xp. install the driver, plug your camcorder using your usb. upload your videos from your camcorder to your pc using ULEAD MOVIE MAKER. edit it and save it with any various types of videos. finish!
CHARCOIS
Panasonic... | Answered on Aug 17, 2011
This can be caused by several problems including a defective eject switch in the cameras internal circuitry or a bad motor and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
yer like trhe guy said flick the top mine works great now cheers mate
Panasonic... | Answered on Mar 29, 2011
Use http://www.downloadvideos-convert.com/download-videos-music
1. Download Video Download Studio, install it.
2. Go to the interface, you can download (Automatic capture) the YouTube video there directly. Tab Download to Convert, you can also click "Add" button to upload the videos from computer. You can also edit video by trim and crop functions.
3. After the video display on the Video Download Studio, click "Profile" and choose "General audio", then select an MP3 format. Set destination file, clicking Convert button to complete the task.
Not only convert video to MP3, but also support batch conversion. Safe and easy to operate. No Viruses, No Spyware, No Adware. Do not hesitate. Have a try!
Panasonic... | Answered on May 24, 2010
Hello
Thank you for using FixYa for your problem
It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Panasonic... | Answered on Feb 21, 2010
Hi
If you're using windows XP, the camera will be automatically identified.
Anyhow, try the following:
1. Check the cable for any possible defects.
2. Switch off the computer.
3. Connect the cable to both the camcorder and the firewire card.
4. Switch on the computer.
5. Switch on the camcorder.
If the cable and the firewire card are both okay then it is possible
that the camcorder firewire interface is damaged.
good luck
Panasonic... | Answered on Dec 19, 2009
You may need a MiniDV head cleaner tape. Read the instructions on the tape carefully and good luck.
Hi
Thanks for using FixYa. This issue arises when the Camcorder is not operated for a long time.
Gently knock on the push button simultaneously opening the cassette holder and insert the cassette. Now push on the right side and gently push the holder back in position and press play, fast forward and backward one by one. The Camcorder will now accept the cassette. If still the issue persists, then repeat the above steps until the issue is resolved. It is recommended that always store the camcorder in a dust and humidity free area and always remove the battery and cassette when not in use.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Panasonic... | Answered on Dec 17, 2009
I had the same problem. In desperation, I picked up my trusty can of compressed air and aimed a few shots into the recorder/playback mechanism. Worked like charm.
Panasonic... | Answered on Apr 04, 2009
Panasonic Palmcorder PV-GS14 Mini DV Digital Camcorder Logo
33 questions posted
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
View Most Popular
Palmcorder Panasonic
  • Palmcorder Panasonic
Most Popular Question
push reset button
  • Video Cameras
