20 Most Recent Daewoo L700C 17" Flat Panel LCD Monitor Questions & Answers
Screen turns black
problem with the inverter chek it
2/18/2019 5:53:13 AM • Daewoo L700C 17"... • Answered on Feb 18, 2019
3answers
Screen goes black, but power light is on (not blinking)
The problem is not with your screen. Its the problem of Video Card of your system which is unable to send Video Signals to the Screen.
11/29/2015 6:17:30 AM • Daewoo L700C 17"... • Answered on Nov 29, 2015
Dsl-173d How much would it cost for a new t-con board
This monitor is from about 2002, and would cost more to fix than to replace.
7/20/2014 2:43:34 PM • Daewoo L700C 17"... • Answered on Jul 20, 2014
Daewoo L950SC Monitor will not turn on
Plz Cheak your pawer cable.
12/21/2013 6:45:41 AM • Daewoo L700C 17"... • Answered on Dec 21, 2013
L950SC Monitor screen has only a white screen?
Plz check the brightness and contrast from the menu on the monitor.
12/21/2013 6:44:06 AM • Daewoo L700C 17"... • Answered on Dec 21, 2013
2answers
SCREEN MESSAGE - MODE NOT SUPPORTED
You have set a resolution that is too high or incompatible with your monitor. I assume you are using Windows. Turn the computer on and immediately keep pressing F8 on the keyboard until the 'Windows Advanced Options Menu' appears. Use the Up and Down keys to select 'Enable VGA Mode' Press enter and your screen will work again when windows starts. Now go to the display properties and click 'Advanced' then click the 'Monitor' tab and tick 'Hide modes that this monitor cannot display' OK everthing and now you should be able to adjust the resolution without getting a blank screen again! Good luck and come back to comment soon. Regards
12/21/2013 6:37:32 AM • Daewoo L700C 17"... • Answered on Dec 21, 2013
2answers
I have a flat screen Dawoo monitor model L10AV
cybertripp, What is correct model number from rear of unit and the date of manufacture? Not cable problem!!! You will need to open monitor and investigate power supply board for "thermal cycle fractured" solder joints on the printed circuit board. You will need large magnifying glass or low power inspection microscope (5x to 20x) to find pesky intermittant solder joints which will need to be resoldered. May also have problem with "BAD" (premature failure) electrolytic filter capacitors!! Swollen tops indicate problem!!! Lots of pictures on web. You need visit to YOUTUBE for DIY video clips of typical repairs to lcd monitor power supply/inverter supply. Then you will know what generates the 600 to 1000v ac required to light the tiny but small diameter fluorescent lamps in back of the lcd panel that is now black and lifeless!!! Do your investigation first to determine if you can handle the repair or contract out the work ($40 to $90) Reply to this response with info on just what you will do about your black screen lcd monitor. 12fixlouie
10/15/2010 3:09:31 AM • Daewoo L700C 17"... • Answered on Oct 15, 2010
My daewoo lc1700c will not turn on. no matter how
Open it up and look at the capacitors. The round "tin can" looking components. If the tops appear bulged, then replacing them may help. Check out the YouTube video... and web site...
http://www.youtube.com/watch?v=9Q6_TgNJvQw
Good Luck!
5/15/2010 5:58:28 AM • Daewoo L700C 17"... • Answered on May 15, 2010
More likely to be failed capacitors in the power supply, see example of failed monitors due to bad caps (most common failure): http://s807.photobucket.com/home/budm/allalbums
Post back what you see so we can guide you further.
3/19/2010 3:53:00 AM • Daewoo L700C 17"... • Answered on Mar 19, 2010
Monitor goes black
Ok the issue with that is your hard drive has crashed so you need to get a new one for your laptop.
6/18/2009 7:25:20 PM • Daewoo L700C 17"... • Answered on Jun 18, 2009
Monitor keep going to black screen while viewing.
Disable the Screen Saver in the Display Properties from Control Panel of your Computer.
A Black ScreenSaver is active in your Display Settings. Change it to "NONE" and your problem will be solved.
4/27/2009 7:06:28 PM • Daewoo L700C 17"... • Answered on Apr 27, 2009
Computer Monitor
hmmm chek the power board in the back chek resistors and ic's in ocilloscope good luck
2/10/2009 8:59:31 PM • Daewoo L700C 17"... • Answered on Feb 10, 2009
Daewoo L700C 17 in. Flat Panel LCD Monitor
www.dtforum.net search here
2/10/2009 8:53:05 PM • Daewoo L700C 17"... • Answered on Feb 10, 2009
IBM LCD Screen turn deem
If my research effort is accurate, _dim_ LCD screens are typically caused by problems with:
-- The inverter
-- The backlight
-- The screen itself.
Apparently it tends to be a pick-and-chose effort to diagnose the problem.
I'm not quite sure you mean that the LCD display is built in with the motehrboard ... are you sure you don't mean the video card, or is this an all-in-one product?
At any rate, you may get some tips here:
http://repair4laptop.org/
They almost certainly will not have your exact model of computer/laptop/screen/whatever it is you're trying to fix, but you may be able to look at other products and see what's involved in changing parts. If it really is an LCD _monitor_ that's bad, depending on your technical expertise, patience, mechanical aptitude, available money, and such, you may just want to replace it. Or try a few parts ...
12/5/2008 11:45:06 PM • Daewoo L700C 17"... • Answered on Dec 05, 2008
Black screen
How old is the computer? Make sure that the power light comes onto the monitor when you plug it in, should be orange and then turn green when video card syncs with it when PC is turned on. If you are getting black screen when PC is powered on:
1. Bad video card
2. Bad video cable
3. Bad monitor
1Solution: Try using a different monitor attached to this same PC and see if it works. If it does, then its the monitor, its cable, or its power supply. If it doesn't work, then its the video card or the video cable coming from monitor.
10/18/2008 2:29:49 AM • Daewoo L700C 17"... • Answered on Oct 18, 2008
Lcd computer monitor
Have you checked out the Comnputer on another Monitor? Are you sure it is the monitor.? Check the data cable some times pins can get bent through rough insertion.
4/24/2008 1:02:44 AM • Daewoo L700C 17"... • Answered on Apr 24, 2008
Daewoo L700C 17" Flat Panel LCD Monitor Logo
Popular Tags
27 questions posted
Top Daewoo Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Daewoo Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Daewoo Computers & Internet
Most Popular Question
green light goes but screen stays
  • Computers & Internet
