20 Most Recent Compaq P 1220 (Carbon, Silver) 22 in.CRT Conventional Monitor Questions & Answers
Copy-protected DVDs prohibit people from copying them, which is piracy. Copying a DVD to sell or even to give away is illegal. You can play copy-protected DVDs in a standalone DVD player or in your computer's DVD drive, as long as your computer's software is up to date. These DVDs will play the same as DVDs that are not copy protected
Press the "Eject" button on your DVD player to open the DVD tray. Set the DVD into the tray, and push the "Eject" button to close the tray. Press the "Play" button on your DVD player, and the DVD will play. b> On a DVD Drive on a Computer Press the "Eject" button on your DVD drive to eject the DVD tray. Set the DVD into the DVD drive, and push the tray in to close it. Click the "Start" tab on your computer's home screen to open the "Start" menu. Click on "My Computer" to open it. Click on the DVD drive to open the DVD. Click on "Autoplay" to play the DVD.
Compaq Computers... | Answered Yesterday
A dvd burner will burn anything you tell it to burn, the things is you need certain programs to see what the extension was that you burnt.
EX- if you burn a DIVX file, windows media player won't see it, but it will see a WMP file.
The most important thing is the burning software, makes it easy to burn boot, ISO files, video.
But like I said, a DVD burner will burn anything you tell it to burn.
Compaq Computers... | Answered on May 08, 2019
Firstly enter the bios screen and set your boot device from HD to USB. Insert your bootable USB drive and start the machine.
Compaq Computers... | Answered on Apr 23, 2019
Assuming you have iTunes installed....
Connect iPod, when iTunes opens, you can go to File ---> Add File to Library (or press Ctrl+O), find the music file on your harddrive, highlight, and click ok. You can then manage the id3 tags (Genre, Artist, etc) by right-clicking on the song, and selecting "Get Info"
Hope this helps!
-- RT
PS - Don't forget to vote!
Compaq Computers... | Answered on Apr 17, 2019
format data coded not supported
convert it through a converter software . eg,XVID TO VOB.EXE or MPEG it will work
Compaq Computers... | Answered on Apr 10, 2019
Hello Dear,
with this model only AMD Processors are compatible
please check this
https://www.support.hp.com/us-en/document/c01861126
in
Processor upgrade information
Compaq Computers... | Answered on Mar 25, 2019
what Linux
non stated, of 100s.
why post lacking such key facts.
NO PC sated, just a nebuluas complaq.
no OS stated, just linux something
why not ask on YOUR linux forum.
try Ubuntu? yet?
best is to match PC old to Linux old.
but be impossible for me to guess what PC you own.
Compaq Computers... | Answered on Mar 01, 2019
I am pretty sure you can't boot an OS from a USB. Burn the install media to a disc or put it on a spare partition. USB boot is for anti-virus or PC Diagnostic Tools.
Compaq Computers... | Answered on Feb 23, 2019
That sounds like your hard drive may be dead...
Compaq Computers... | Answered on Feb 22, 2019
Xp had a lot of issues with shutdown early on, but they should have been mostly resolved.
1. Make sure windows is up to date, IE all updates.
2. Make sure all drivers are up to date.
3. Run some anti virus/adware/spyware programs, could be something preventing your computer from shutting down.
4. You aren't unplugging and USB/firewire devices without stopping it first are you?
Compaq Computers... | Answered on Jan 05, 2019
If you are more than just a beginner you can attach that drive to your PC and run a drive copy program that will create an exact image of your current drive. Once that is created then you can add the new drive to the computer make sure your system recognizes it and can boot from it. I have done this many times.
Compaq Computers... | Answered on Dec 27, 2018
Lights can come on but your CPU is not booting the Operating System. Can be the Hard drive or windows os.
Compaq Computers... | Answered on Dec 25, 2018
Dead PC, PC fans totally dead
that most times means PSU dead, or shorted modules inside PC> (im sure the power switch wire, to the mobo did not fall off) and the green LED on back of PSU is glowing green , (per manual HP ) means AC power side is good.
SR1200 series desktop made in fact in the Compaq plant in Texas.
2004 newest 2002, oldest.
if the coin cell is that old, it is bad.
none ever last that long; 14 years to 16year old batteries are no good. but a DMM check will not lie to you. 2.9v min, lower bad.
If both fans are dead , the PSU is bad.
in some cases, (no pun) we open the case
power off, (ac cord pulled)
push power on to discharge all caps in the PC,
normally one sees the CPU fan spin for 1 seconded and die. (but that is good PC yours is not)
we remove all power wires from the PSU from it
to HDD, to CD, drives, and to floppy 4 pin power
we do that because shorted devices, cause all PSU to shut down. even in 1/2 of second or LESS.
by design (ATX spec) this prevents fire, in the case/psu.
plug in PC, AC and push power, do fans run now, both must run , not just one fan.
power off again, ac line pulled, push power button again, to discharge things,
now
The once all those pig tails from PSU to THINGS are pulled , but not your MAIN 20 pin connector to mobo
we do what, we remove ram and test each stick 1 by one.
doing same tests, AC line pulled. remove RAM.
but 1 stick reseat it, and test for power on again.
if you have the original DDR memory sticks test them 1 by 1, each. ok>? they can short too. 94c62a99-50e0-4817-b127-42fc295914d0.jpg
Compaq Computers... | Answered on Nov 24, 2018
Compaq P 1220 (Carbon, Silver) 22 in.CRT Conventional Monitor Logo
0 questions posted
Top Compaq Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Compaq Computers & Internet
Most Popular Question
boot from usb compaq evo n1020v please
  • Computers & Internet
