20 Most Recent Sony CPD G420 19" CRT Monitor Questions & Answers
Sony CPD G420 -- Monitor
I can presume that your monitor is turned ON or at standby power supply all the time 24/7. That makes the power supply is always availabe on circuit boards. 1. check the data cable or switch to new one... 2. Open your monitor there is data bus cable connected to LCD monitor from circuit board. clean it with CRC cleaner.. beware that the spray is done only and only on the socket of that cable.... 3. Reinsert that cable and check again... I think that due to continuous operation of LCD monitor some carbon has been deposited inside the jacket.
4/16/2019 2:43:28 PM • Sony CPD G420... • Answered on Apr 16, 2019
I have a Sony G420 CRT monitor which is starting
dear..... to do it set.... you have to open the box with due care as the electricity of the equipment should be turned OFF.... There is a main cable connected with the center of CRT and going onto a section of board called flyback.... is picture can easily been seen on net..... the rotate is anticlock slowly and you will find that brightness of you CRT is getting dimmer.... set is where you want.... actually its screen voltage regulation
6/3/2017 10:32:47 PM • Sony CPD G420... • Answered on Jun 03, 2017
just unplug the signal cable and see if it shows a warning! if it shows then the monitor is in some working condition! this problem mainly is not the monitors problem its the systems problem, it seem as if the system is in standby when u on it right??? it happens when the processor doesn't get supply or it refuses to come on! you will see that the red hdd load led will not light when u start the CPU; just open the CPU and unplug the smps from the board and blow the pins to clean them up and re-fix it and see it will work. if still it doesn't work try some other smps it will work! reply and revert back for more help with a vote!
7/24/2010 8:51:29 AM • Sony CPD G420... • Answered on Jul 24, 2010
Lcd turns red
is there a speaker or magnet adjacent to the monitor?
12/27/2009 12:42:00 PM • Sony CPD G420... • Answered on Dec 27, 2009
2answers
Hi, I hope you can help. I have a Sony Trinitron
you have to open your monitor back. find a big part called flyback. there is two nossel in it. adjust forcus nobe litte bit for clear picture. this will definetly slove your problem.
7/19/2009 11:10:01 AM • Sony CPD G420... • Answered on Jul 19, 2009
Standby problem
bear.....my HMDA400 CRT Sony ..is doing the same thing....you need to discharge the CRT of static, then open the case and vacume the boards, heat sinks and every thing soldered down, strap grounds and the glass tube CRT.
Then run the self diognostic from the manual ..its simple and will tell you if the problem is major...usually it is a pwr issue...ie the pwr strip outlet may be shorting or pulsing erratical out put....bad strip......if the self diognostic shows the monitor is bad....best thing to do is replace the main monitor PC board to avoid testing other componants with speciality equpment you don't have! Last resort replace the CRT...the most expensive piece of the puzzle...ie the picture tube it self...
try a good known monitor on your system to be sure you don't have a software, or CPU problem or pwr glitch.....know this ,a black screen with no raster(lines, visuals) could be a sign of a faulty FBT(fly back transformer)...it happens with CRT units...sucks doesn't it...and you would be advised to" wear rubber gloves" to replace the FBT yourself....because of the dangerous voltage stored in the damn things.....its the current not the voltage that is deadly.....two hands on any circuit is not good....one hand at a time when taking parts out and putting them in.....get rid of rings watches and other conductive bling on your wrists and hands!....you will thank you me for that! good luck!
7/16/2009 5:35:22 PM • Sony CPD G420... • Answered on Jul 16, 2009
Picture is far too large,
on your crt's manual menu you can resize the screen hit the menu button on your screen to begin or you can try the auto button
5/9/2009 1:13:19 AM • Sony CPD G420... • Answered on May 09, 2009
Monitor
Is there still power to the monitor or is the screen just black? Do you hear any sort of sound when it goes black? Does the time the picture goes out vary or does it happen after say "X" minutes/hours everytime? Do you have any power saving software activated that would cause the monitor blank out? Check display properties? Sounds weird but have you checked for any viruses or spyrus nasties? If its hardware it could be many different things. Let me know what happens. Good Luck Tim
3/15/2007 7:18:26 AM • Sony CPD G420... • Answered on Mar 15, 2007
0answers
Sony CPD 200SX 17" CRT Monitor: Upon resuimng
Monitor has gone to monitor heaven. time to do some shopping since repair not cost effective.
4/4/2017 4:11:43 PM • Sony CPD... • Answered on Apr 04, 2017
Cant get on sony acid music studio 5.0 cause i dont have my serial number anymore please help
We can't helpwith that but you could contact your software supplier and ask for a copy.
4/10/2024 11:55:56 AM • Sony Computers &... • Answered on Apr 10, 2024
Sony Vaio PCG-9S1L. Can anyone upload the owner manual. Thanks
Question edited for clarity, and toss in CAPS. Duplicate question deleted. Refresh page to see your question. Whatever you are trying to do with this Mr Chan, you are wasting your time. It is a Vintage computer running Windows 7. The manual is here
Sony VAIO PCG series Manuals
ManualsLib https://www.manualslib.com > ... > Laptop We have 1 Sony VAIO PCG series manual available for free PDF download: User Manual. Sony VAIO PCG series User Manual (202 pages). https://www.google.com/search?q=Sony+Vaio+PCG-9S1L+owner+manual ....
4/6/2024 7:02:02 PM • Sony Computers &... • Answered on Apr 06, 2024
Sony VRD-MC1 DVD RW Dual Layer. I have been using it many years, but have problems. What do I have to do now please?
Question edited for clarity and made into written English. If you got 6 to 10 years use, you just buy a new one for $15.97. https://www.google.com/search?q=Sony+VRD-MC1+DVD+RW+Dual+Layer ..
10/26/2023 1:10:51 AM • Sony Computers &... • Answered on Oct 26, 2023
SONY CX330 camera shutting down
Why do they need to be turned on all the time? If your using them as security cameras they are not designed for that job. The 330 could be overheating because of the constant use. Some cameras have a built in 'Overheat' switch which could be switching it off. These cameras are designed for short periods of use, recording things like parties and holiday trips. How old are these handycams? These do get old and the technology in them can wear out if in constant use.
9/18/2023 2:00:07 PM • Sony Computers &... • Answered on Sep 18, 2023
Where can I get Sony Control Cables needed for ST-S101 & TA-F101r?
Depending on your location. You have to go to a computer accessories closest to you. Yes you can definitely get it.
7/22/2023 7:40:47 PM • Sony Computers &... • Answered on Jul 22, 2023
Sony sound forge pro 11.0 serial number
Magix can supply you with that.
SOUND FORGE Pro - Download music editing software free
Magix https://www.magix.com > music-editing > sound-forge... SOUND FORGE Pro enables professional audio editing at the highest level. Download the music editing software now for free! ..
7/9/2023 6:13:23 PM • Sony Computers &... • Answered on Jul 09, 2023
I need an amplifier board for my Sony HCD-GNV111D / MHC-GNV111D
this is a question and answer forum manufacturers do not read this forum. You may want to look on eBay or other places that sell parts.
6/28/2023 3:26:24 PM • Sony Computers &... • Answered on Jun 28, 2023
Sony CPD G420 19" CRT Monitor Logo
18 questions posted
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
CPD Sony
  • CPD Sony
Most Popular Question
sony cpd g420 monitor
  • Computers & Internet
