probably not-- you will have to see if there are the same number of stud holes, the same daimeter studs, the correct length of the studs, the same pitch circle diameter of the studs and the off set of the centre is the same
it means the the charging system is not charging at the proper voltage could be to high or to low use a volt meter it should be around 14.8 while it's running
