20 Most Recent
Hyundai ImageQuest L17T 17" LCD Monitor Questions & Answers
L17T
If you can open the cover of your monitor try to locate the fuse maybe the fuse is busted replace it.
if the fuse is blown or busted again there is short circuit in your power supply maybe the diode or the power transistor is shorted you need this to bring to the shop for services
2/16/2009 5:59:00 PM •
Hyundai...
Answered
on Feb 16, 2009
Self turn on and off
please change i.f board if problem not solve thet means problem with lcd panel
1/15/2009 8:27:17 AM •
Hyundai...
Answered
on Jan 15, 2009
White startup screen
try this test: put pc into hibernate mode and allow full cycle. if monitor ceases problem, then original problem may be with pc's video output only.
12/10/2008 2:32:59 PM •
Hyundai...
Answered
on Dec 10, 2008
MONITOR BLICKS AND NOTHING COMES ON THE SCREEN
Grateful how? Neverminding that detail, perhaps your screen's backlight or the power supply for it has failed. There's nothing to do but compare your unit's operation with that in the Service Manual or that of an operating unit; this is complicated by the fact that components might send an OK signal back to the main controller, so removing the bad parts will not necessarily mean the unit behaves normally otherwise. It may be as simple as rinsing the cat barf out with water and D.I. water (but you would still have to open the thing up on towels to find out.)
Of course the main power supply might also be faltering. you can probe the supply (with a DVM or scope) to see how steady that is.
5/11/2008 11:05:27 PM •
Hyundai...
Answered
on May 11, 2008
