20 Most Recent Sony SDM-HS73 17" Flat Panel LCD Monitor Questions & Answers
Problem with powerup for my screen
Although you didn't list your operating system, I'm assuming it is Windows and offering a suggestion to clear up the issue based on that OS. Go to settings, and then to control panel. Once in control panel look for "power settings" and click on "custom". This will allow you to turn off all power saving modes by clicking "never" on when the screen is turned off or goes to sleep. If the issue is caused by the power saving mode, this will end the problem.
4/25/2017 3:01:27 AM • Sony SDM-HS73... • Answered on Apr 25, 2017
Monitor color settings not being maintained
Sorry to hear you're having this issue, Josh. To clarify, you can get the proper colors if you set them manually, correct? If so, that rules out the possibility of a screen issue or a problem with the video card. I hope for your sake this is a new monitor for you (or at least one that would still be covered under warranty), for it sounds like it's a logic issue in the monitor itself that prevents saving of the proper settings as well as the distortion of the presets. I would return it if possible for a replacement/refund, as they seem to be a quality product...it just looks like you got a defective one. Sorry I couldn't be of more help to you, but good luck! :)
11/8/2013 12:49:25 PM • Sony SDM-HS73... • Answered on Nov 08, 2013
Color calibration
check the settings
11/7/2013 5:44:50 PM • Sony SDM-HS73... • Answered on Nov 07, 2013
Monitor keeps going black, turn power button off,
The problem is in the inverter board it is on the verge of failure, it is caused by bad capacitors in most cases and will eventually go. The board must be replaced or an attempt to repair the old one.
2/15/2011 10:21:48 PM • Sony SDM-HS73... • Answered on Feb 15, 2011
What is bulb length for
Please read here: http://lcdparts.net/howto/selectccfl.aspx
It is where I get my replacement lamps from.
I hope you do have real steady hands.
http://s807.photobucket.com/albums/yy352/budm/Sony%20SDM-HS73/#!cpZZ1QQtppZZ20
Basic LCD monitor and TV troubleshooting guide: http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting http://www.fixya.com/support/r7406380-tv_training_manuals Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague Parts: www.shopjimmy.com Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps. Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series. Please post back what you find. Please leave rating if it helps.
1/28/2011 1:28:31 AM • Sony SDM-HS73... • Answered on Jan 28, 2011
Monitor goes off, on/off button turns yellow
It is truning yellow can be because it is not getting the video signal from the PC, I would check the video cable and aslo try it with another PC first. If it is monitor problem, then please read on.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on: Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SONY to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/ Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide: http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide http://www.fixya.com/support/r7406380-tv_training_manuals Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series. Please leave rating if it helps.
1/14/2011 9:50:26 PM • Sony SDM-HS73... • Answered on Jan 14, 2011
2answers
I keep geting out of range 53.8khz/85hz on my
Did you set your PC video resolution to the native resolution of this monitor? It should be set to 1280x1024 @60Hz.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
10/29/2010 2:19:04 PM • Sony SDM-HS73... • Answered on Oct 29, 2010
My monitor screen is a bright green color
Please check all the pins at both end of the VGA cable, also try it on another PC also since the problem can be in the video card. We need to narrow dow the problem first.
4/29/2010 12:14:29 AM • Sony SDM-HS73... • Answered on Apr 29, 2010
My monitor won't turn on
It can be bad caps or bad lamps assembly. see pictures here: http://s807.photobucket.com/albums/yy352/budm/Sony%20SDM-HS73/
4/4/2010 2:53:29 AM • Sony SDM-HS73... • Answered on Apr 04, 2010
The hinge that holds the monitore base broke off.
you can use a OEM wall support base or desk LCD monitor support. if you ask to sony they give a new monitor (only), the monitor is one piece set (box)
2/14/2010 12:56:06 PM • Sony SDM-HS73... • Answered on Feb 14, 2010
Blinking Screen
The fault could be a faulty inverter board which supplies high voltage to the CCFL lamp or the CCFL lamp is faulty.
You maybe be able to get service, parts and DIY info from LCD Parts. Click on this link to their WEB site :-
www.lcdparts.net
These other sites may also be useful.
http://www.yallstore.com
http://www.shope2.com/
http://cgi.ebay.co.uk/I565-LCD-Screen-Display-replacement-for-HTC-S740-S743_W0QQitemZ390065288445QQcmdZViewItemQQptZUK_Computing_LaptopAccessories_RL?hash=item5ad1b3f4fd&_trksid=p3286.c0.m14
11/16/2009 7:14:30 AM • Sony SDM-HS73... • Answered on Nov 16, 2009
Screen stays on for 1/2 sec, power light stays green
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
8/14/2009 6:01:15 AM • Sony SDM-HS73... • Answered on Aug 14, 2009
My monitor wont stay on.
May sound wierd, but Its windows, try going into safe mode, and changing the screen size, (1024 x 768) sometimes, it gets put on a size that doesnt fit your pc/screen, so it turns off.. Like I said, go into safe mode, and change it around and reboot untill it works.. I had that issue once.
5/23/2009 10:25:29 PM • Sony SDM-HS73... • Answered on May 23, 2009
My sony sdm-hs73 has white lines on the display
The display Has been damaged you have lost some of you input will problem need a video broad replacement.
Good Luck
Keep me posted.
3/16/2009 8:24:47 AM • Sony SDM-HS73... • Answered on Mar 16, 2009
Sony SDM-HS73 17" Flat Panel LCD Monitor Logo
28 questions posted
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
SDM Sony
  • SDM Sony
Most Popular Question
monitor color settings not being
  • Computers & Internet
