20 Most Recent
Cyber Acoustics Accent S-3022 Computer Speakers Questions & Answers
How to set up
these speakers are easy to setup. The two speakers are already connected to each other, and the out cable comes from the speaker with the power and volume. The subwoofer and power also connects to that speaker. you would liked to have had the second speaker have the ability to totally disconnect from the main speaker, and you would also have liked to have had a headphone jack built into one of the speakers. Besides that, these are very easy to use, press power, turn the volume to a desired level, pretty straightforward. thanxs
Speakers buzzing
This is probably omitting from your sound card to prove that try them on a diffrent computer if that was the cas ethe sound card will need to be replaced.
Thanks and please leave postive feedback Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Why does my sub woofer not work
it could be a connection from not grounded to your aux cords being crimped and messed up could be amp or could be a setting on your radio..
Cyber Acoustics CA-3618 subwoofer cuts in and out.
Crackling noise and cut outs generally mean that the speaker is torn, or the cone is separated from the driver. This means the speaker is broken irreparably. It sells for $40 now, which means it is not worth fixing. These low cost speakers are built to not be taken apart.
HDTV Digital coaxial output to CA-5001
The speaker system has RCA jacks that connect to and from the Speaker system and you Computer/TV/Player/ or Amplifier. There are no Coaxial IN/Out on this system. It is not HDMI, only a standard 3 wire sound system. Front (green), Center (Yellow) and Rear (Black). Correspond the colors with the RCA input on the computer or other devices you wish to use it with.
