20 Most Recent JVC GR-D60 Mini DV Digital Camcorder Questions & Answers
2answers
I have a JVC GR-D60EK
Depending on the operating system, you may see a wizard for installing new hardware has been detected. Should only be taken to select the type of device USB drivers and as soon as you have the option to select the CD drive (CD must be inserted JVC), thus the wizard search for drivers on the CD.
Keep in mind that laptops using x64 software. The drivers are installed from the CD supplied with your camcorder.
Once everything is properly set up the camcorder going to behave like a removable hard drive, a quick and easy way to see it go into My Computer or Windows Explorer you should see a unit here called DISK. Also, check COMPATIBILITY with your Operative System.
In the case that after attempting to install does not work, you can download the latest updated drivers from JVC website in the downloads section, where you will find various software and among them the USB driver (will be downloaded in compressed format). Once in the download section, the link in question is the following: USB drives, then select the model of the camcorder.
Other driver sites:
- http://members.driverguide.com/driver/detail.php?driverid=134664
- http://list.driverguide.com/list/company539/
Hope this helps.
7/19/2011 10:26:53 PM • JVC GR-D60 Mini... • Answered on Jul 19, 2011
Camcorder says condenastion in it. gow do I fix
This is usually caused by a failed component in the moisture detection circuitry within the camera and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
10/10/2010 9:47:40 PM • JVC GR-D60 Mini... • Answered on Oct 10, 2010
When i switch it on the lcd screen foes not come
Hi I am vortash one of the big problems with digital cameras especially the type that the screen folds out like the one depicted in this picture , is that the Plastic and copper ribbon that connects the screen to the circuit is prone to cracking and breaking hence no picture on the lcd .
So the only alternative unless you can do it yourself ( and this is not advisable unless you dont mind if you muck it up lol ) is to take it to a local engineer for repair , or return it to the manufacturers for a quote on repair .. regards Vortash
3/30/2010 9:15:06 PM • JVC GR-D60 Mini... • Answered on Mar 30, 2010
Condensation operation paused
that is the dew sensor making this,
try whit an air dryer a low temp set
and blow air inside for a few seconds max a minutes
and let it rest for a while and try it again
removed the battery out befor doing this
if it not work you needs to replace the sensor(dew)
usely its work/ dont forgot to eject your cam
have a good day..
3/5/2010 5:27:13 PM • JVC GR-D60 Mini... • Answered on Mar 05, 2010
I need the manual for jvc digital vedio camera
I think this might be it:
http://safemanuals.com/user-guide-instructions-owner-manual/JVC/GR-D53-_E
You can download free (it will ask you to confirm a screen, but thats just to deter autoscrapers stealing them all).
3/4/2010 8:53:24 AM • JVC GR-D60 Mini... • Answered on Mar 04, 2010
When I switch on the unit it says
I just left the unit switched on and after about 1 hour the message cleared, then I was able to use the unit.
1/12/2010 1:03:29 PM • JVC GR-D60 Mini... • Answered on Jan 12, 2010
I have purchased a/m item
This a fairly generic mechanical error code for JVC (may as well say re-attach lens cap,which would work as well as battery).The problem will most likely result in replacement of mechanism or drum motor to restore normal operation.Either way part cost is upwards of $100.00 and may not be cost effective.My suggestion would be to contact mfg,as they have had many complaints regarding this error on this model and see if they will accommodate you in some way.Contact JVC support at www.jvc.com
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
12/20/2009 1:22:06 PM • JVC GR-D60 Mini... • Answered on Dec 20, 2009
LOST SOFTWARE DISC JVC GR-D60
best thing to do is check the softwares on Google.....
http://www.helpdrivers.com/ingles/listado/panel.asp?marca=jvc&perif=camaras
check that web site!!!
9/6/2009 5:58:25 PM • JVC GR-D60 Mini... • Answered on Sep 06, 2009
FINAL CUT EXPRESS
you can use tod to final cut express converter or mod to final cut express converter.
click:
http://www.fceconverter.com/tod-to-final-cut-express/
or
http://www.fceconverter.com/mod-to-final-cut-express/
8/6/2009 4:18:45 AM • JVC GR-D60 Mini... • Answered on Aug 06, 2009
5answers
Lost my webcam installation cd
i need jvc pc820 cd installer for my webcam so that i can install it on my pc
coz i lost my cd and i cannot used my jvc pc820 cam.
your prompt action is highly appreciated...
Thanks...
3/5/2009 2:05:03 PM • JVC GR-D60 Mini... • Answered on Mar 05, 2009
2answers
How do i put a tape recording onto the pc?
Unless the video is stored on the memory card you cant transfer it directly, you need a video capture device, it is an attachment to your Computer that manages the transfer of taped video copies to digital...
5/28/2008 11:54:53 AM • JVC GR-D60 Mini... • Answered on May 28, 2008
Blur in viewfinder
Hi, i had the same problem and was suggested i visited the JVC website, this could be the manufacturers error reported on their web site. Failure of the CCD image sensor. Check JVC UK web site, support centre, if your camcorder has the problems listed, until 01/10/07 they will cover repairs. Mine now works ok. Hope this helps
6/21/2007 8:00:36 PM • JVC GR-D60 Mini... • Answered on Jun 21, 2007
I have a jvc camcorder model gr-d350u that will not come out of safeguard mode
Not sure , do you mean safe mode ?
1/24/2019 4:34:16 PM • JVC GR Video... • Answered on Jan 24, 2019
JVC GR-D60 Mini DV Digital Camcorder Logo
35 questions posted
Top JVC Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
View Most Popular
GR JVC
  • GR JVC
Most Popular Question
lost webcam installation cd
  • Video Cameras
