20 Most Recent
Dual Club Car Lester Power Drive Charger 30 Amp Link Fuse Kit | Golf Cart Questions & Answers
MY 1993 CLUB CAR GOLF CART WILL NOT MOVE, I HEARD
check to see if there is a circuit breaker on the wire path from your batteries. Could have blown the motor but You would see some smoke more than likely, and smell it burning. What you described with the popping sounds like an electrical short where the wires just burned up but again you'd smell it and maybe see smoke. The switch may be bad also check it with a meter to see it its making contact and see if voltage is coming up to and exiting the switch.
Club car gas will run but will not pull
Check the drive belt. goes between the centrifugal clutch mounted to the engine. Usually 2 shinny "V" shaped cones that look line this ><. The belt goes between the cones (where the "x" is: >x<). The belt may have broken or slipped off or needs to be replaced or adjusted.
