20 Most Recent
JVC GR-D71 MiniDV Digital Camcorder Questions & Answers
Condensation, operation paused
keep it charged thru the main electrcity connection and put the knob on the play mode and let remain for couple of hours. it should warm up n do the trick - after this use the cam more often.
NO IMAGE IN MY VIEW FINDER OR LCD SCREEN
the ccd image sensor of your camera is the
problem...i know it is free for replacing that sensor..that trouble is
also in sony,canon,samsung and the other cameras brand cause the
manufacturer of their sensor is only one company that why they recall
it from the batch of 2002 to 2004..log on to the jvc costumer care to
see all the detail...
Why won't my digital camera charge via USB anymore?
Take camera and its battery to a camera outlet, ask them to check the built-in rechargeable battery.
Most outlets will help you with this, as its likely that if the battery has failed, you'll buy a replacement from the same dealer.
My GR_SMX730U VHS camcorder is eating the tape.It uses a PRO TC-30 casset.
that means the head is sticky or the takeup rollers are icky
take it apart . clean all the parts the tape touches with something thats strong but little water .
as for the head very carefull clean it when you get to the actual holes where heads are only use a proper qtip wetted . look it up or youll break them.
on the rubber rollers scrub them . then load the tape an watch it run.
its easy to fix this but you need a nice clean place an some small phillips , take pics of parts/screws if needed
