20 Most Recent KDS 17S 17" Monitor Questions & Answers
Where the power outlet
Normally is on the back at the bottom of the bump it has in the back just follow the monitor cable it will be at the right side of the Monitor to computer cable
4/18/2011 5:45:02 PM • KDS 17S 17"... • Answered on Apr 18, 2011
2answers
Screen has blurry lines
its a problem with your graphics card try replacing the card
9/12/2009 3:57:01 PM • KDS 17S 17"... • Answered on Sep 12, 2009
2answers
No power
Check your power cord very carefully....especially the plug ins (square box)....could be the power supply itself. Regarding fuses; You can't see it inside the computer it is an electronic component. Got to go to store
2/27/2009 11:33:06 PM • KDS 17S 17"... • Answered on Feb 27, 2009
Black screen blinking green light
You have a bad backlight fluorescent bulb.
2/17/2009 8:25:25 PM • KDS 17S 17"... • Answered on Feb 17, 2009
0answers
Power light blinks and blank screen after power outage
Burned out backlight fluorescent bulb.
12/28/2008 8:46:43 PM • KDS 17S 17"... • Answered on Dec 28, 2008
2answers
KDS Silver 17 inch monitor
Hi again,
Am not sure what happened but I lost you in the Chat/Live Session. For a while I saw you typing a message ... and then it would appear that for some reason, the session was ended.
With your indulgence, I would post the additional steps:
  • If the LCD is receiving power, then probable faults could be the main board that processes the video and controls, the CCF (cold cathode lamps and/or inverter. This of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional;
  • If you are considering a DIY, the unit has to be opened up and the fault determined. In most cases, it is the inverter. This could actually be verified by running the LCD monitor and let the PC boot even if not visible. You could try shining a lflashlight at an angle on the display and see if there is a semblance of your desktop except that it would be very dark. If yes then it is possibly the CCF lamps or most likely the inverter.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
12/27/2008 4:57:44 AM • KDS 17S 17"... • Answered on Dec 27, 2008
I have a KDS XF-9e that is not working with two
Disable cross fire and see if the issue goes away.
3/3/2017 2:45:40 PM • KDS Computers &... • Answered on Mar 03, 2017
No sound
then your speakers are bad,not plugged in or not plugged in properly
6/22/2015 4:01:39 AM • KDS Computers &... • Answered on Jun 22, 2015
How to brighten monitor
i have a few thing to help you with this problem, but first if the monitor old, used a lot or left on all the time than it is time for new on. first right click on screen using the mouse than go down to screen resolution than find the detect button after thats done go to Identify select that one, after you done all that than go to advanced settings and open the folder, than check the adapter, monitor, troubleshoot, color management, than select color management check all settings. 2 way is to go to control panel open color management folder, for your general information for you monitor and other options you mite want to review understanding color management settings find advanced tab find calibrate display, it will run a lot of tests and have you answer some question about visual site and what you like in the settings of the monitor. you mite look in to video card manufacture and see if they have any tools for the drivers game apps or programs that runs other than video card drivers, like i have nvidia video card and i went to there website and downloaded so software, nvidia control panel for gamers, 3d adjusting color settings and video image settings, change the aspect ratio, resulation, refresh rate, lots of tools for games and gamers and i do not play a lot of games but i like to have a lot of option that i would not have had before. thank you rod PS make sure all drivers are up to date you will find it in control panel and than open device manager and find video drives, monitors, display adapter.
3/15/2015 7:02:54 PM • KDS Computers &... • Answered on Mar 15, 2015
2answers
KDS k 72mb
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor. 2. Verify the monitor cable is firmly connected to the computer and the monitor. 3. Verify that you have turned the monitor power switch on. 4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works). 5. If the power light on the monitor is not on, try a different power cord. 6. If the power light is on and yellow or flashing, but nothing displays, borrow a monitor from a friend. If that works, your monitor needs replaced.
12/12/2014 9:31:20 AM • KDS Computers &... • Answered on Dec 12, 2014
Turn power on stays on few mintues then shuts down turn power off and back on does same thing screen looks a little dim
what kind of computer do you have what kind of os or operating system windows xp,200, vista just to name a few
9/10/2014 4:29:08 AM • KDS Computers &... • Answered on Sep 10, 2014
How do you clear memory??
you probably need to clear the history as it is probably full
9/10/2014 4:27:28 AM • KDS Computers &... • Answered on Sep 10, 2014
Why won't my K917s 900p monitor show my MAC Pro screen?
get rid of the new installation it is not compatible with your system
9/10/2014 4:26:34 AM • KDS Computers &... • Answered on Sep 10, 2014
Where can I get kds computer monitor repair?
try any computer repair shop
9/10/2014 4:24:33 AM • KDS Computers &... • Answered on Sep 10, 2014
KDS 17S 17" Monitor Logo
12 questions posted
Top KDS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Eric
ADMIN Eric
Are you a KDS Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • KDS Computers & Internet
Most Popular Question
screen blurry lines
  • Computers & Internet
