20 Most Recent KDS RAD-5GS 15" Flat Panel LCD Monitor Questions & Answers
0answers
Rad-5 LCD has no picture
This usually means the power board is not putting out the correct voltages to run the monitor correctly. The power board can be repaired if you can solder parts. Check out the pictures on our web site at:
www.ccl-la.com/badcaps.htm Now open the back of your monitor and check for parts that look like the blown capacitors in the pictures on our site. Replace any that you see and you should be back running again. The values you need to purchase will be marked on the sides of the bad ones that come out of your board, it will be marked like 220uf, 470uf, 1000uf etc and a voltage value. Be sure to order a high quality part not like from Radio Shack, also use a high temp replacement 105c marking. If you don't want to do the repair yourself we do offer a repsir service for $35 plus return shipping. Let me know if you have any additional questions.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
10/7/2014 3:37:55 AM • KDS RAD-5GS 15"... • Answered on Oct 07, 2014
The monitor says out of range what does this mean
This means the graphics card video settings is set incorrectly.Go to Control Panel - Display - Settings tab and change the Screen Resolution to 1024 X 768 (you may change it to a higher resolution later) then click on Advance button - Monitor tab and change the Screen refresh Rate to 60 Hertz. (you can increase it to 72 later if required)
11/22/2012 12:13:31 AM • KDS RAD-5GS 15"... • Answered on Nov 22, 2012
Monitor has vertical lines down right side of
Check to see if there is dust in the vents on the monitor. Blow them out with canned air or dust them with a brush the best that you can. The lines could be caused by over heating which usually happens when the vents are plugged by dust.
If this does not solve the problem then the monitor has overheated to the point of burning pixels and needs to be replaced. Over time the lines with grow wider and wider until they cover your screen.
9/27/2010 6:35:51 PM • KDS RAD-5GS 15"... • Answered on Sep 27, 2010
4answers
KDS RAD-5 monitor set up
THE POWER SUPPLY PLUGS INTO A WIRE STICKING OUT OF THE END THAT PLUGS INTO THE COMPUTER
4/1/2009 12:48:14 AM • KDS RAD-5GS 15"... • Answered on Apr 01, 2009
THE MALE PLUG
if it is a yellow plug it is for a built in microphone.
2/26/2009 10:04:17 PM • KDS RAD-5GS 15"... • Answered on Feb 26, 2009
I have a KDS XF-9e that is not working with two
Disable cross fire and see if the issue goes away.
3/3/2017 2:45:40 PM • KDS Computers &... • Answered on Mar 03, 2017
No sound
then your speakers are bad,not plugged in or not plugged in properly
6/22/2015 4:01:39 AM • KDS Computers &... • Answered on Jun 22, 2015
How to brighten monitor
i have a few thing to help you with this problem, but first if the monitor old, used a lot or left on all the time than it is time for new on. first right click on screen using the mouse than go down to screen resolution than find the detect button after thats done go to Identify select that one, after you done all that than go to advanced settings and open the folder, than check the adapter, monitor, troubleshoot, color management, than select color management check all settings. 2 way is to go to control panel open color management folder, for your general information for you monitor and other options you mite want to review understanding color management settings find advanced tab find calibrate display, it will run a lot of tests and have you answer some question about visual site and what you like in the settings of the monitor. you mite look in to video card manufacture and see if they have any tools for the drivers game apps or programs that runs other than video card drivers, like i have nvidia video card and i went to there website and downloaded so software, nvidia control panel for gamers, 3d adjusting color settings and video image settings, change the aspect ratio, resulation, refresh rate, lots of tools for games and gamers and i do not play a lot of games but i like to have a lot of option that i would not have had before. thank you rod PS make sure all drivers are up to date you will find it in control panel and than open device manager and find video drives, monitors, display adapter.
3/15/2015 7:02:54 PM • KDS Computers &... • Answered on Mar 15, 2015
2answers
KDS k 72mb
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor. 2. Verify the monitor cable is firmly connected to the computer and the monitor. 3. Verify that you have turned the monitor power switch on. 4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works). 5. If the power light on the monitor is not on, try a different power cord. 6. If the power light is on and yellow or flashing, but nothing displays, borrow a monitor from a friend. If that works, your monitor needs replaced.
12/12/2014 9:31:20 AM • KDS Computers &... • Answered on Dec 12, 2014
Turn power on stays on few mintues then shuts down turn power off and back on does same thing screen looks a little dim
what kind of computer do you have what kind of os or operating system windows xp,200, vista just to name a few
9/10/2014 4:29:08 AM • KDS Computers &... • Answered on Sep 10, 2014
How do you clear memory??
you probably need to clear the history as it is probably full
9/10/2014 4:27:28 AM • KDS Computers &... • Answered on Sep 10, 2014
Why won't my K917s 900p monitor show my MAC Pro screen?
get rid of the new installation it is not compatible with your system
9/10/2014 4:26:34 AM • KDS Computers &... • Answered on Sep 10, 2014
Where can I get kds computer monitor repair?
try any computer repair shop
9/10/2014 4:24:33 AM • KDS Computers &... • Answered on Sep 10, 2014
I need the dc in power cord for modelax191 rad-9
the power cord is the same for all makes and models if you have one then i bet it will work on yours
9/10/2014 4:22:27 AM • KDS Computers &... • Answered on Sep 10, 2014
KDS RAD-5GS 15" Flat Panel LCD Monitor Logo
13 questions posted
Top KDS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Eric
ADMIN Eric
Are you a KDS Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • KDS Computers & Internet
Most Popular Question
monitor says out range mean
  • Computers & Internet
