20 Most Recent Sony Handycam DCR-TRV310 Digital Camcorder Questions & Answers
How do I eliminate droput of audio/video upon playback?
If it is an old tape which has been used before, there may be creases caused where the pinch wheel pressed against the roller. Try again with a brand new tape. If this is not the issue, he a service is called for.
6/17/2017 8:30:15 PM • Sony Handycam... • Answered on Jun 17, 2017
Error code C:31:20
T reel side tape slacking when unloading. Need a service
10/4/2012 10:32:20 AM • Sony Handycam... • Answered on Oct 04, 2012
6771 to us-b connection
You can buy it from any sony dealer
1/19/2012 8:42:49 AM • Sony Handycam... • Answered on Jan 19, 2012
My Sony HandyCam DCR-TRV310 Doesn't
You may have a defective mode switch or the problem could be an electronic issue. The camera will need to be disassembled to trouble shoot the problem to be certain. This can be repaired fairly inexpensively. However, it's not really a user serviceable problem and should be done by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
9/12/2011 1:06:16 AM • Sony Handycam... • Answered on Sep 12, 2011
Camera lost power while filming. Cannot recharge.
This is usually caused by a failed component in the power circuit within the camera and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
9/6/2011 12:25:09 AM • Sony Handycam... • Answered on Sep 06, 2011
Is there a way a
It seams that this camcorder uses digital 8 media for storage ..and it does record digital ..so the transfer should not be a problem ..but it has no slot for any kind of external memory so the direct record to a external drive or flash is not possible ...but ..the way to upload the footage is simple and you just have to use a firewire cable ..and capture the footage on a video manager like windows movie maker..
The procedure is just like any other tape camcorder...just plug the cable ..let the computer see the camera ..and than use the video manager to import or capture the video while it is played back ..
If your operation system does not have a movie maker ..use the one recommended by Sony on the support site ..or any other which has the capacity to capture from device ..
The only way to capture directly to the computer's hdd is also with a video manager..but the camera needs to have the ability to stream ...To try it and see if it is able to ..just plug it with the wirefire...open the movie maker..and choose to capture from device and see if you have any image on the preview..If it does..it means it is capable to stream and capture in real time on the movie maker..than be saved as a video file on the hdd..
8/5/2011 3:40:41 PM • Sony Handycam... • Answered on Aug 05, 2011
Sony dcr-trv310 control buttons will
Very likely that your control operation panel has a bad connection or just needs to be replaced. This repair would need to be done by an experienced technician.
Hope this helps you.
www.austintelstarservices.com
7/23/2011 4:50:39 AM • Sony Handycam... • Answered on Jul 23, 2011
I would like to convert
I think you are expecting camera to covert VCR analog video-audio signal into digital so it can be record in Macbook?
Camcorder will not do this job and you need to hookup VCR with DVD Recorder to burn DVD of VHS tape.
7/21/2011 10:57:49 PM • Sony Handycam... • Answered on Jul 21, 2011
SONY DCR-PC101 It has a tape
It sounds like your battery is bad, or dead. Try charging the battery. If it won't take a charge, replace your battery. I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
7/2/2011 10:20:21 PM • Sony Handycam... • Answered on Jul 02, 2011
Error 31:10 keeps ejecting cassette
This can be caused by several problems including the transmission gear in the tape mechanism not engaging properly or a defective clutch in the take-up spool and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
6/22/2011 1:47:58 AM • Sony Handycam... • Answered on Jun 22, 2011
Sony dcr trv 310 just got
I suggest check in the Sony TVR 310 user guide about SteadyShot Function (page 29)
Hope helps.
4/26/2011 8:32:28 PM • Sony Handycam... • Answered on Apr 26, 2011
I want the CD identifier
sony esupport.com
3/21/2011 6:53:09 PM • Sony Handycam... • Answered on Mar 21, 2011
I have a Sony Handycam
I've never fully troubleshot a camcorder, but I would think they probably have a fusible link as protection, however, you should make sure the battery terminas inside the camcorder are clean (use a qtip and alcohol, or a pencil eraser). I would also suspect the on/off button as being oxidized or broken. You can open it up and try to check these things, but it might take some tracing out the circuitry without a schematic, which would be difficult to obtain.
You might check on Ebay for a working unit- it might be easier, or an alternative.
Good luck, and hope this helps.
1/4/2011 8:03:14 AM • Sony Handycam... • Answered on Jan 04, 2011
Sony handycam dcr-trv310e code error
This is the most common problem in Sony camcorders of various models. It is most likely a problem with a rubber bushing on the inside. It is an easy fix but it is very hard to explain with out pictures. Here is a link to a GREAT tutorial however, it is written in Japanese. All you need to do is follow the excellent pictures and this should take care of the problem. The plastic tube on the inside of the rubber bushing is the most likely cause so just follow the pictures. He uses a drinking straw to fix this. Good luck. This has fixed my camera perfectly!!!!!!!!! http://d.hatena.ne.jp/tomo_snowbug/20090207/1233989258
12/4/2010 6:48:20 AM • Sony Handycam... • Answered on Dec 04, 2010
"sony handycam dcr-trv310
Required video head cleaner tape is available in Amazon.com
Thanks.
4/26/2010 9:34:55 PM • Sony Handycam... • Answered on Apr 26, 2010
It wont eject or play makes lound noise for a min
There is a broken plastic part on the cassette. Needs to be replaced.
Mostly caused by improper position of the tape and camera jam(tape jam)
needs sony camera technician who can replace the part inside the cassette.
4/3/2010 6:52:03 PM • Sony Handycam... • Answered on Apr 03, 2010
2answers
Camera acts dead. Hasn't
I need exact model number of your Sony camcorder to find out reason of no power up problem.
Please check charger output volts with multimeter as it should be equal to written on back of charger, approx 10V DC
Thanks.
3/27/2010 6:17:27 PM • Sony Handycam... • Answered on Mar 27, 2010
Sony Handycam DCR-TRV310 Digital Camcorder Logo
58 questions posted
Top Sony Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
View Most Popular
Handycam Sony
  • Handycam Sony
Most Popular Question
sony dcr trv 310 just got
  • Video Cameras
