20 Most Recent
Sony Handycam CCD-TRV11 8mm Analog Camcorder Questions & Answers
Tape plays but nothing on
This is usually caused by an oxidized or defective Audio/Video drum. Try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Where can i get
I use partsdirect.com for some of my purchases but more so i use Sears service dept. They are an authorized Sony repair facility and can help with parts and accessories for your electronics. I did some research and found the part number to be "147928319". I hope this helps.
Display has eject "d"
this is a tape transport problem. something is broke inside..samsung builds their transports outta plastic. they get broken easily
Handycam tape door
problem could be as easy as cleaning the video head and tape path making sure it a dry. video drum may be binding.
Camera wont play or record has message c:31:23
Basically, the error message indiactes the reels are not turning, either because of a defective tape or a fault in the mechanism. Try a new tape. If the problem persists, you will have to have the camcorder serviced. please be sure to rate this solution. Thanks!
AC-V16A
Your'e Battery is damaged, thats all.
Gr Diver
