20 Most Recent
Sony Handycam DCR-TRV20 Mini DV Digital Camcorder Questions & Answers
Dcrtrv20 windows 7 driver
http://esupport.sony.com/US/perl/support-info.pl?template=&info_id=544No drivers needed. Window 7 does not support streaming. All info in the Sony link above.
I have a miniDV cartridge
This can be caused by several problems including a defective eject switch in the cameras internal circuitry, a stripped gear or a bad motor. This will require disassembling the camera to repair and can usually be done fairly inexpensively. However, it's not really a user serviceable problem and should be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
I am trying to record
For that to have a chance at working you will need to have an s-video cable for the picture part and standard audio cables for the sound part...that way the VCR is putting out a digital signal to the camera...
Then follow the setup instructions and make sure that you have it set for input from outside source..
I find that many times the manufacturers test this under very controlled conditions, but often in the real world it does not work so well...
heatman101
Where is the firewire port
On the right side, front of the camera - just in front of where your hand holds onto the camera are some ports behind a plastic covering that just snaps open for use.
I have a japanese DCR-trv20
Yes, but you have to read the Japanese to get back to English. I suggest using Google Translate to read the Japanese. Go to the Google page and select "more" and then select "Translate".
DCR-TRV20 Problem when reproducing the video.
THESE HAVE A COMON PROBLEM WITH THE PINCH ROLLER RETAINER. THEY CRACK AND WORK THEIR WAY UP AWAY FROM THE PINCH ROLLER AND SOMETIMES FALL OUT COMPLETELY. IF YOU CAN FIND IT ,THEY CAN BE TRIMMED AND REINSTALLED. LARRY
Zoom feature
What is the exact model number of your Sony camcorder? Seems its tele/wide switch is bad and requires replacement.
Memory Stick Error, PLEASE HELP!!!
Does any other Sony memory stick still work in your camcorder? If yes, means memory stick isn't match with this camcorder. Use Sony memory stick.
