20 Most Recent
Hotpoint RLA31 Compact Refrigerator Questions & Answers
Hotpoint rla31 motor constantly running/freezing at the back
Your fridge is cooled by the freezer, the thermostat is within the Fridge to tell it to shut off, you might have a bad fan or a build up of frost where the air is sent to the fridge, check where air goes to the fridge when it's running, if you don't feel air flow then something is up, best thing you can do is take everything out and allow the fridge to defrost, at leat 24hrs. then see what happens, if you don't feel air flow after the defrost then you fan is shot and you'll need to replace it.
We have a hotpoint RLA 34 ( MICROBAN ) FRIDGE .
You said no blocked drainage hole, where was the drainage hole that you checked located? Did you pour water down this drain, and furthermore did you check that the water you poured into the drain flowed into the condensate pan on the outside of the fridge? Unless you have a problem with an ice maker leaking water, it sounds very much like you do have a blocked drainage hole, otherwise known as a defrost drain. the drain system begins underneath the evaporator coil inside the freezer, this is where the water that is collected in the defrost cycle flows into a drain tube that leads the water down to the condensate pan. The best and safest way to clear out this drain is to blow it out with compressed air, after you remove any and all ice at the beginning of the drainage system, in other words, the hole located underneath the evaporator coil.
Problem with drawer configuration. I have a Hotpoint Freezer. Model FZA84.
Does the problem move with the drawer when you shuffled them or did it do the same thing in the same position? If it moved it's the drawer causing the issue, if it stayed in the same place it's the freezer itself.
Empty the offending drawer and have a good look at it. A lot of front panels on freezer drawers are a 'push on' fit so check the front is clipped on correctly on both sides. Next check the runner rails and back panel of the area that drawer goes into. It might be something as simple as a lump of ice or something stuck to the side/back or a something in the drawer above or below blocking it.
6/28/2023 5:17:16 PM •
Hotpoint...
Answered
on Jun 28, 2023
I heard some clicking noises
yes . it sounds like the main board . the clicking would be the relay that starts compressor ... change the main board .. mm feed back pls . with a model # i can give you part # & price .
5/17/2023 6:40:48 AM •
Hotpoint...
Answered
on May 17, 2023
