20 Most Recent
Sony Handycam DCR-TRV30 Mini DV Digital Camcorder Questions & Answers
The negative wires on the
You should be able to use the RCA connections (yellow/red/white) and plug it directly into a VCR to record. You can also get a cheap capture card to record directly to your computer - but you need a decent machine to process it. There are several sources around for the connection to the computer to camcorder do such what you are doing... I’m happy to help further over the phone at
https://www.6ya.com/expert/jason_60e0f57ba319f3f6
DCR-TRV30 Internal clock battery is end of life.
This small back-up battery on my Sony is under the main big power battery, it is like a large screw under the main power pack, I just turn that screw and the little round lid comes off to get to the little silver flat back-up one.
They are readily available from most good camera shops like Jesops for around £12 to £15 each.
My Sony TRV30 MiniDV camcorder always gives me an
This can be caused by several problems including the transmission gear in the tape mechanism not engaging properly or a defective clutch in the take-up spool and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
My Sony DCR-TRV30 Mini DV video camera stopped
I'm afraid, its mechanical problem in your DCR-TRV30 camcorder and visual check is necessary to inspect mechanism function properly to diagnose problem.
Beeping and displaying error sign is an indication that camera got problem for some reason and there are many possible causes for that like capstan motor is not rotating or rotating on fast speed, video head motor is not spinning, any loading gear got broken, above said motors are not getting power etc etc.
Take your camcorder in nearest local camera repair shop to diagnose problem.
Thanks.
How to copy
use s video cord or red white yellow cord to connect. camera comes with a grey adapter patch cord that will help do that easily.
Playing on TV. .
there should be a "hidden"hole for it on the camera,it will have A/V-out near it.
usualy its covered by a rubber cover/plug.
Tape Will Not Eject
Please make sure that tape flap should be straight as shown in below image...
If tape flap will stuck or turned like below image, tape wont be pulled out.
let me know if need further help / info.
Good luck.
Loose Focus ring assembly
IF YOU TAKE A LOOK AROUND THE FRONT OF YOUR CAMERA THERE ARE SEVERAL SCREWS, ABOUT 4 I THINK,
1) 1 ON BASE
2) 1 ON THE LEFT LOOKING AT FROM THE FRONT
3) AND 2 INSIDE THE FLASH CASE
REMOVE THESE SCREWS AND THEN YOUR FOCUS RING AND SOME OF THE CASE SHOULD COME OFF
INSIDE THE FOCUS RING YOU SHOULD SEE 3 SREWS IF NOT CHECK THE CAMERA TO SEE IF THEY HAVE FALLEN INSIDE,
IF NO JOY YOU CAN REPLACE THE 3 MISSING SCREWS AND PUT IT ALL BACK TOGETHER
SWEET
DAVOS69
HOPE YOU DONT MIND BAD SPELLLLLING.........
Sony Handycam TRV30 - Loose Lens
hi
sounds like the screw that holds the ccd is gone
but its inside
you say it all works good....?
put a SMALL!!! drop of "superglue" (3 sec glue)
it will hold nice
good luck
