20 Most Recent
Sony Handycam DCR-DVD100 DVD Camcorder Questions & Answers
Sony Handycam DCR-DVD100. Get
Hi! As a first course of action please link the handycam and the pc via usb. By then you can copy the files from the handycam and hopefully it will open. But if not, then the dvd itself is faulty. You will need a replacement for it to work normally again. Hope this helps and thank you for using FixYa!
I have a sony DCR-DVD100 that has been in storage
Try Resetting the Camcorder. To Reset the Camcorder, first open the LCD of the Camcorder to locate the Camcorder(on the side of the Camcorder, next to RECORD and VOLUME buttons). Then, press and release the RESET button using a sharp pointed object. Then, check whether the issue is resolved.
If the issue still persists service of the Camera is required.
You may also try changing the battery.
Sony handycam
you told that you are getting previously recorded one that means the screen is safe.and there will a button to change the screen for recording to thr right side of the cam or at the back of the cam try it and see.if still your are not getting it then recording part is damaged.
My Camcorder is in full
Let me know do you see correct picture in playback of previously recorded disc?
If yes, Then camera has ccd imager problem and that part needs to be replaced.
Let me know about playback question to help you more.
Disk access door won't close
This sounds like the door latch is broke or stuck it may have to be sent in for repair...go to
www.sony.com customer service and they will take good care of you!
this should fix ya!(please eate me acordingly!,This is what keeps this free site running
Thank you!
Disc Access error
Clean the optical lens in camera with nice quality soft cotton swab.
Would record images
DCR-DVD100 is mentioned in free of cost CCD replacement scheme announced by Sony.
If you want to replace it by yourself then it requires few $$ and soldering expertise.
I would recommend to contact Sony and let the job done by Sony experts. You will spend $15 in shipment, Click
Sony Support for details.
Good Luck.
Picture is distorted blurred lines
i had same problem. Mine was a product defect issue and although it was out of warranty Sony repaired as this is a problem that they have had with lots of these cameras. Call Sony.
In English: 1-800-222-7669
Hours: Mon-Fri 9:00AM-10:00PM / Sat-Sun 10:30AM-7:15PM EST
Cannot view dvd made from sony handycam
- here is the link to download codec software
- www.amazon.com/tag/camcorder/forum?_encoding=UTF8&cdForum=FxB43NWTLP4H3B&cdThread
THANK,YOU don't forget to rate it..
Black scene frame
i think you have changed the screen into other mode so that you are unable to see the recording picture there will be a switch to change the mode at the back of the cam or at the right of the cam.
Dropped handycam
i think if your handycam warranty still is there then its better to exchange it other wise check the battery still you are having problem you have to take it for repairing
My sony handycam dcr-100 DVD
The charger what u have got is not rite... get a charger which goes rite wit the battery u have...and there is a problem with the lens of your camera.. that is the reason why u r not able to record anything.... thank u
