C:31:42 shows following error.. FG fault during normal drum operations. Its related to drum assembly (video head) in camcorder and possible reason can be drum stuck with some thing, no power to drum motor etc.
ok now you hold your breath and follow the instructions..
1. remove all the batteries including the tiny backup battery (usuall seen behind the screen)
2.then hit it very hard..
now insert the batteries and check ..
if you dont belive read the link
http://www.camerahacker.com/Forums/DisplayComments.php?file=Video%20Camera/Sony/DCR_PC5E_Error_code_C_21.00.html
all the best
regards
sreejith
GT Recovery for Windows Download: www.gtrecovery.net.
Lost your photos on Android phone & need to recover deleted pictures, try GT Recovery for Windows- the World's 1st Data Recovery Software for Android smart phones.
It can directly recover deleted pictures, photos lost due to deleting, restoring factory settings, flashing ROM, rooting, etc., from SD cards inside Android devices.
It let you preview the deleted photos before recovery. Watch the video tutorial to learn how to retrieve photos from Android phone easily with simple clicks.
Key features of Data Recovery - GT Recovery for Android:
1). Preview & selectively retrieve photos and video lost due to any problem
2). Support all Android phones/tablets, like Samsung, HTC, LG, Motorola...
Please be sure to rate my answer as a 3 or 4 thumbs up if you found it useful (1 or 2 thumbs-up are like saying "Didn't help or wasn't what I was looking for")
For me, the alcohol sensor cleaning didn't work. I did some research on how the sensor works and it turns out the black stuff is conductive in low humidity and resistive in high humidity. That means the circuit need to be cloed to work,, cleaning off the black substrate would only open the circuit furthur, I cant understand why removing the black substrate is working for some people. After cleaning it to no avail, I tried bypassing (shorting) it. To test it I just took an ordinary pencil and filled in some conductive carbon where the black square was. And it worked. I could have bypassed the sensor by shorting the 2 solder contacts, but to reach it I would have to take it all apart. I'll make the bypass permanent when I have a day free.
Try this. Remove the memory stick your camera. If
there is a LOCK switch on the back of the Memory Stick Duo, please be
sure to set it to the unlocked position before attempting to delete or
write data to the stick. If the switch is left in the locked position
when attempting to delete or write, the data on the memory stick may be
damaged.
Tape mechanism problems can be quite complicated. This will require disassembling the camera to repair the tape mechanism and can be done fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
This is usually caused by an oxidized or defective Audio/Video drum. You can try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be serviced by a qualified service technician.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
This can be caused by several problems including the transmission gear in the tape mechanism not engaging properly or a defective clutch in the take-up spool andcan usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repairedby a qualified service technician.
Hi, If video head got clogged then camcorder wont read tape in playback so result comes as blue screen. Please use video head cleaning tape and clean video head of camcorder. This will solve your problem. Video-8 head cleaning tape is available with amazon.com Thanks.
This is usually caused by an oxidized or defective Audio/Video drum. Try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be repaired qualified service technician.
The error code C:32:20 is a take-up reel malfunction. The ejection malfunction is something else and can be caused by several problems including a defective eject switch in the cameras internal circuitry and can usually vbe repaired fairly inexpensively. However, it’s not a user serviceable problem and will need to be repaired qualified service technician. My name is Rick and I’m a professional repair technician with over 20 years in the business and have repaired many of these. I’m semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs. If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
This code means
"FG fault during normal drum operations. Load the tape again, and perform operations from the beginning."
'C' indicates consumer-fixable problem. '31' indicates the fix method (remove casette). The 'FG' signal from the capstan motor is the tachometer signal that the camera uses to monitor the rotation of the capstan.
