20 Most Recent
Sony Handycam DCR-TRV950 Mini DV Digital Camcorder Questions & Answers
I have a SONY DCR-TRV950
Hi there, I've just posted my own answer to the same problem, my own problem, elsehwere on here. My solution was to insert a Firewire card into my PC and use that port. I checked with Sony and they said my original USB cable and port was not appropriate with Windows 7 64 bit, that a Firewire port was best. When such a Rirewore port is used then the correct driver automaticllly become available to you, if you have Windows 7 that is. I probably wrote the answer much better first time around on my other posting.......
Switch on
Please try reinserting the battery. Also try with AC Adaptor. If the issue persists, service may be required.
C:32:11 thats what is flashing
The error code C:32:11 indicates a problem in the tape mechanism rotary mode switch.
This can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
I was using the camera
This is usually caused by a failed component in the power circuit within the camera and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
C 31:23 error
This can be caused by several problems including the transmission gear in the tape mechanism not engaging properly or a defective clutch in the take-up spool and can be repaired fairly inexpensively. However, it’s not a user serviceable problem and will need to be repaired by a qualified service technician.
I am a electronic tech and I had a DRCTRV950 come
This can occur when the heads do not spin up fast enough or the loading does not complete. Check for slipping of the loading belt. There is more load placed on the loading motor and mechanism in total when the tape is actually there. The flashing Eject indicates that the load did not complete.
Hope this helps a bit.
Dan
I'm trying to clean the heads on my TRV 950, I
Follow these steps to resolve the issue:
Step 1: Remove the cassette and insert it again , then operate your Camcorder.
Step 2: Try using different cassette.
Step 3: Try resetting the Camcorder.
[Resetting the Camcorder will reset the settings of the Camcorder to the factory settings including date and time. It will not delete any data saved in the Camcorder.]
Please locate the RESET button behind the LCD screen of the Camcorder. Press the RESET button using a sharp-pointed object. The Camcorder should be switched ON when you reset the unit.
Step 4: Try to power reset the Camcorder and check if it helps to resolve the issue. Power Reset the Camcorder by removing the batteries from the Camcorder and inserting it after 1 minute.
Step 5: Service is required.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C79466
Download video from camera to computer
Do you hve a FireWire output in the camera? (IEEE)
If yes, connect it to your computer.(You need a firewire card in your computer too ($10 on ebay))
If you do not have a firewire, you will have to use your video out of the camera to capture. Then you will need a TV card/Capture card to capture the video. (you can just plug in your AV out from the camera to the capture/tv card and use the software come with it.)
You can simply use Windows Movie Maker to get your videos to yor computer.
Cheers!!!
What does C31:40 mean?
These errors are fixed in my experience by resetting the camera with the power on. The reset button is located (very small) on the function panel behind the LCD display. Activate with a pencil or similar.
Good luck.
Sony DCR-DVD200 camcorder not turning on after trying to fix it.
The best thing you can do now is to take it to a specialist and get them to do the repairs. Camcorders have a lot of electronics in them and can be easily damaged if your a not an experienced repairer. You might also have to consider that this camcorder might not be repairable.
