20 Most Recent Mag Innovision lt456s 14" Flat Panel LCD Monitor Questions & Answers
Hi, Check on the side, back and on bottom of screen for plug in. Good luck.
Mag Innovision... | Answered on Sep 27, 2014
see are u sure that cable is for that slot...
try to open it as slider or use some lever to open it
Mag Innovision... | Answered on Oct 14, 2012
windows problem, not monitor
dbl-click on clock and change it
Mag Innovision... | Answered on Jul 28, 2011
You need laptop-type 12V, 2.5A (minimum) adapter plugged into back of VGA plug
nope, no speakers
The correct one would be 12v @ 2.5 to 3 Amp.
If the set used less current than 1 amp it would be in milliamp (500ma which is half an Amp)etc.
As long as you get one that is 12v @ 2.5 to 3 amp it will be fine.
You could buy one with a higher current rating like 4,5,6 or more Amp's as long as it's 12v DC. The set will only use the current that it needs to function so I higher current won't hurt. It's the voltage you have to make sure is correct. If you do buy one with a higher current rating it will probably last longer because it wont get so hot.
first check the power cable connection at both end i.e. source of power and also at monitor side if loosen one tight it or may try to change the cable
If you ask them nicely they just might tell you, else it's only $5 for a user manual(sorry no luck online); http://www.maginnovision.com/service.htm this link has a picture that maybe shows a power cable going to the bottom right (as you look at it) but it's hard to be sure; http://www.amazon.com/gp/product/customer-images/B0002CF06K/ref=cm_ciu_pdp_images_all/104-1966292-9407907?ie=UTF8&s=electronics#gallery this link shows what the power lead should be like - look for a hole that matches; http://cgi.ebay.ca/AC-power-adapter-for-MAG-innovision-lt456s-14-LCD_W0QQitemZ8824271526QQcategoryZ3698QQssPageNameZWDVWQQrdZ1QQcmdZViewItem Hope this helps, if not ask again :)
no never use those one
it will belt ur curcuit in ur moniter
my friend lost his monitor juct cos of it
buy a new proper one
I think you are experiencing something that happens a lot when you change monitors, possibly 'downsizing'? Your graphics settings on your actual PC were set too high for the new, smaller flat-screen, so what you'll have to do is hook it back up to another monitor, even an older CRT-style one, and then do the following steps before hooking it back up to your new 14" LCD:
  1. boot into Windows as usual, but on an older, perhaps larger monitor
  2. right-click on any empty area on your desktop, then left-click on 'Properties' at the bottom of the little pull-down menu that pops up
  3. when 'Display Properties' window comes up, click on the very last tab to the right, labelled ''Settings'
  4. find the 'Screen Resolution' slider bar about two-thirds the way down that window, and adjust the slider control to a more standardized, universal setting, like '800x600', or even '1024x786'. Either of those should work with your new LCD flatscreen.
  5. make sure you click 'OK' on that window, then 'Shut Down' Windows properly (using the Start button, and all that)
  6. disconnect your old monitor, and hook your new one back up. It should work!
This happens a lot. I build HTPCs, so it's even worse the more 'options' you have, believe me.
Hope this helps!
Mag Innovision... | Answered on Mar 10, 2011
Hi Jeff,
Not sure what you are trying to connect, This monitor is over 8 years old. It will only have a VGA connection and the power connector. If you are looking for a DVI connector, it does not have one.
The connections it does have would be on the bottom edge of the monitor.
Thanks for using Fixya.
Mag Innovision... | Answered on Dec 23, 2010
restart the computer press and hold F8 key and select enable vga mode your problem will be solved
Mag Innovision... | Answered on Mar 14, 2010
Your resolution is probably not set correctly. That monitor can only support a resolution of 1024x768 - so to change that, you'll need to go into Start - Control Panel - Display Settings, and then click on the settings tab, and near the bottom where it says "display resolution" drag the slider until it says 1024x768. Press apply or ok and see if that helps.
Mag Innovision... | Answered on Jan 20, 2010
u will get it on download.com
yeah it is driver problem nothing more
it happened to me too.
Mag Innovision... | Answered on May 17, 2009
see i use Compaq too
they don't generally except other modes
did u try that monitor with other pc where it worked
u should install proper monitor software ... u will found it from the cd given wit Ur monitor
Mag Innovision lt456s 14" Flat Panel LCD Monitor Logo
29 questions posted
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
Steve Allison
Steve Allison
Damen Wong
Damen Wong
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
LT Mag Innovision
  • LT Mag Innovision
Most Popular Question
adapter plug in lt 456s
  • Computers & Internet
