20 Most Recent
Mag Innovision InnoVision LT765 17" Flat Panel LCD Monitor Questions & Answers
How to I get the speakers inside monitor to work?
I recently was given a MAG Model 780 too. I found the input for speakers just today. When looking at the monitor, on the left side behind the monitor you should be able to feel a flat horizontal surface. If you lay monitor down, you will see 2 mini-plug openings. These are your input spots for speakers/microphone. I believe pink is speakers & green is microphone.
No sound from speakers -
Hello,You need to connect the output from your sound card to the 'line in' connector on the monitor.Regards,nicam49
Problems with ON button, need multiple tries for
The start Capacitors are Blown. You are essentially building up enough current in the high voltage side to light the CCFL's. Eventually this method will fail to turn the unit on. You will have to open up the monitor and replace the defective Caps.
Monitor is making clicking noise when powered up
The clicking sound you hear is from the power supply trying to power up.
If you can solder you should be able to repair the monitor yourself.
The problem is caused by blown capacitors on the power board. Go to our
web site at :
www.ccl-la.com/badcaps.htm
We have pictures of what to look for. Open your monitor and look at the
power supply board for any blown capacitors, replace all that you find.
The replacement parts can be ordered from several places on the
internet or we can supply them for you. The replacement parts will need
to be high temp and will be marked 105c. The values you need to get
will be marked on the sides of the ones you take out but will be
something like 220uf, 470uf, or 1000uf etc. and then a voltage rating.
When you install the new ones be sure to insert them with the polarity
stripe going the same direction as the old ones come out. If you don't
want to do the repair yourself we do offer a repair service for $35
plus return shipping. If you have any questions just let us know
I hope this helps if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
[email protected]
No signal on monitor
Dear Brother,
- Check your Monitor Cable
- Check your Cables PINS Broken/Damaged
- Check Properly Plugged in the Cable to both PC and Monitor
- Check your Display Card
- Check your Motherboard Connection With Display Card
- Unplug the Cables end From PC and Monitor
- Unplug From Power too and Then Correctly Plug in
- Connect CPU to another PC(for making Sure problem is for Monitor)
Your Problem can be Solved......
Hope This HELPED YOU
Thanks For Using FixYa
I tried turning on my monitor and it wouldn't turn on
The first step is to make sure the plug you have the power cord plugged into is supplying power to the monitor. [surge protector? Check the switch or the reset button]. Check for the powered on light, usually in the power on button on many computer monitors. Yellow usually means a bad connection with the computer. So the monitor is actually on, it just appears off because you have a black screen. Check the video cable linkage to the back of the monitor and the computer's graphics card or digital video out.
If when you "power on" the monitor's on light does not light it means that power is not getting to the unit and you could have a bad power cord. If it is of the universal type that unplugs from the unit you can swap out for a new cord to test this [some monitors have external power supplies as part of the cord and this could be the problem]. If swapping it for another works than that was your problem.
Many monitors though have their power cords mounted via chassis clamps to the unit and have internal power supplies and are not end user serviceable.
If power is making it to the unit there are a handful of possibilities. Unfortunately the majority of them, at that point, involve dis-assembly of the unit's outer casing and is not advisable to an untrained end user. A service call would be required at that point.
Whenever the computer gets shut off randomly, the
hayleyvivian, When Very strange things start to occur with ANY brand of LCD display the first place a technician will look is at the SMPS/inverter power supply for the monitor. One thing you could do is try to swap your display to a fully booted KNOWN GOOD pc with the desktop window showing. If display still does weird stuff, then you will know that it's not your pc screwing up. If you have already swapped-in a different display to your pc to logon the web, you already know it's the monitor that has the problem. Just FYI visit YOUTUBE for video clips of "LCD monitor disassembly" and "LCD repair". You my also want to check out your warranty to see if your covered or if Magnavox will do a swapout+cash for a REFURBISHED unit. Bye. 12fixlouie
MAG Innovision LT765S Model 780 = no audio
If your monitor supports sound (might have to be the LT765s product?), there will be two inputs on the back (to the right when looking at it from the back). One's labeled "Line in." This is where you'd plug the audio cable from your sound card.
