20 Most Recent
Mag Innovision InnoVision LT 765S 17" Flat Panel LCD Monitor Questions & Answers
POWER SUPPLY
check your cables especially to the power supply or check your outlet if it is giving the complete consumption of power to the monitor.
When the monitior is on and the light stays yellow
You are not getting any video out of your computer need to check your video hook up from the back of the computer to the mointor sometimes they slip off. If its not that then you are receiving nothing from your video card from your computer.
When monitior doesn,t come on, but the light is
Yellow light means it is not getting the video signal from PC, try it on another PC first, if it stilldoes not work then you need to open it up.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Mag LT916a/900p
Sounds like the inverter is dying/died. Take a flashlight and shine it directly or at a large angle at the screen - is the picture still there? If so then the backlight inverter has failed (very common). You can either send it off to get fixed (expensive) OR buy a new inverter and change it yourself (sometimes cheap, sometimes expensive) OR you can repurpose another inverter in your monitor (requires electronic skills and experience but very cheap - http://search.ebay.com/search/search.dll?from=R40&_trksid=m37&satitle=ccfl+light+kit )
Your choice
- Chris
