20 Most Recent LG Flatron L1710B 17" LCD Monitor Questions & Answers
2answers
My Monitor all of a sudden just turned off
Most likely gone... it would require an electrician to go testing the different components of the monitor inside. And maybe even someone like that cant fix such things.
1/10/2018 6:52:14 PM • LG Flatron... • Answered on Jan 10, 2018
0answers
2 thin red vertical lines
You have bad LCD panel, it will get worst with more lines.
Basic LCD monitor and TV troubleshooting guide: http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide http://www.fixya.com/support/r7406380-tv_training_manuals Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series. Please leave rating if it helps.
2/27/2011 6:06:01 AM • LG Flatron... • Answered on Feb 27, 2011
2answers
How can I get the 2 USB ports to work on my
try to plug something into it, then try the menu on the monitor. try a manual. if you don't have one, you can read an onlione one on the Flagtron's website.
10/29/2009 1:29:19 PM • LG Flatron... • Answered on Oct 29, 2009
I cannot get it to install on Vista, is there a
Could you mention the computers configuration on which you are trying to install windows Vista and what error or symptoms you are getting when you try to install Vista
Vista installation can fail
1. If memory (RAM) is bad
2. Hdd is corrupt or has bad sectors
3. Optical Drive is Bad
Thanks for using fixya
Proton
8/28/2009 4:11:01 PM • LG Flatron... • Answered on Aug 28, 2009
Monitor continues to flicker
Found the problem was new computer was defective. Under warranty
5/19/2009 10:52:03 AM • LG Flatron... • Answered on May 19, 2009
Monitor turns off
If the picture is Reddish either at top or bottom It could be the backlight failing.If you are technically able you maybe able to Replace the CCFL backlight.
Samir
4/20/2009 4:35:48 PM • LG Flatron... • Answered on Apr 20, 2009
LG 1710b tft monitor - no picture. screen shows 4 hozizontal line
Problem with Interface board or panel.
Also maybe due to defective powersupply filters.
Samir
12/10/2008 11:28:33 AM • LG Flatron... • Answered on Dec 10, 2008
Black marks on screen
This is normally a problem of panel.you need to replace the panel.
Samir
8/8/2008 10:42:07 AM • LG Flatron... • Answered on Aug 08, 2008
5answers
Dark/light horizontal bands...
I would first suggest that you verify the video cable and connector are okay. The connector should look like the one in the photo with no missing or bent pins. if you can plug in another monitor, that would help rule out the PC. After that, it would probably need component-level troubleshooting, probably in the video or signal circuits.
7/5/2008 8:24:01 PM • LG Flatron... • Answered on Jul 05, 2008
Cant get 1280x1024 when connected to laptop
the only way you may get it to work is if you use the monitor a secondary device and also use the notebook monitor as well. But the problem may also be the vga connector converting the signal, as you may have to have a DVI connection on your monitor to obtain widescreen resolutions.
5/28/2007 1:45:25 PM • LG Flatron... • Answered on May 28, 2007
LG Flatron W2252TQ does not power up. When I turn the PC on, the blue light momentarily turns on before turning orange and then reverting back to grey.
ok try this one switch the hard-drive off and on again to restart it and then the screen would come one.
7/19/2022 10:19:51 PM • LG Flatron... • Answered on Jul 19, 2022
I was cleaning the screen of my lg flatron w2053tp and the screen went black. The power is on and I can bring up the menus but otherwise nothing
Check the all the cables. Check input settings by using the menu.
8/3/2021 7:29:51 AM • LG Flatron... • Answered on Aug 03, 2021
Hey I have an LG Flatron L1718S screen that work fine for a few weeks then suddenly switch off for a few days ,then switch on again,it's a irritating cycle.Please HELP
  • Larry Ng Jul 15, 2021that is just a YEAR 2007 LCD computer monitor, it needs a computer to work. if it fails in a 2nd PC , if that test fails,the monitor is bad. (hardward failure, monitor. the tests are simple, it fails on 2nd good PC, what can be more simple that test ANY 14 year old monitor on a 2nd good PC. when dead do this.(test2) they are all here when dead again use a FLASH LIGHT. (or in UK a low carbon foot print TORCH)<< joking. https://pcdied.com/monitors_and_screens/... all monitors older than 2010 do this . (has CCFL inside and that is never fun now) the cure is newer monitors 2011 to now called LED monitor.s or OLED. the tubes are cold cathode florescent tubes. (back lamps.) (have 5 classic fail symptoms not just dead) they are short lived, laptops and monitors both back then. 20,00hours on the clock and go bad. bank on it. the 3 failures are CCFL, PSU board, and logic board #1 is CCFL the all died long ago, on average about year 2003 (07 +5= 12, 2012) at 20,000 yours boom dead. or intermittent. PSU is here: https://pcdied.com/monitors_and_screens/... below is logic board. one of the 3 fail, CCFL tubes dead is like 99% we retire them if the CCFL test fails. (using bench PSU to test them) but you have non of that so. upgrade
  • Larry Ng Jul 19, 2021 logic board. (CCFL tubes dead, PSU dead, or logic board dead) and or thermally failing , and bad.
  • Anonymous Jul 23, 2021 99% of all monitors are all dead. due to those silly low live CCFL back lamps. or the 2cards inside that can fail too. PSU card +HV CCLF power or the Data card is dead. 99.9% of folks seen these facts, upgrade now. high voltage inside 600v on the CCFL pins
7/23/2021 3:55:07 PM • LG Flatron... • Answered on Jul 23, 2021
Monitor slow to display picture
Hi, Sounds like an issue of the video card not the monitor. Take to computer shop to verify. One thing you can try is drop the dpi down (refresh rate)a bit. Then try again. If that makes sense to you. Hope that helps.
2/10/2018 9:41:36 AM • LG Flatron... • Answered on Feb 10, 2018
Installing mount on LG Flatron
Hello, It´s not safe to anchor it to the plastic back, monitors usually have a metal frame inside that support the weight of the monitor.
11/12/2017 9:54:47 PM • LG Flatron... • Answered on Nov 12, 2017
Flatron l17175 has it internal wireles receiver
Flatron l17175 what on earth is that? ahhhhhh and LG, lucky Goldstart monitors. not HP. wrong forum Ill move you.
10/16/2017 11:14:22 AM • LG Flatron... • Answered on Oct 16, 2017
0answers
LG Flatron L1710B 17" LCD Monitor Logo
23 questions posted
Top LG Computers & Internet Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Flatron LG
  • Flatron LG
Most Popular Question
get 2 usb ports work
  • Computers & Internet
