20 Most Recent Mitsubishi Diamond Pro 91TXM 21" CRT Monitor Questions & Answers
Now the monitor flickers..
Your monitor is slowly dying. Get ready for the eventuality and start saving some bucks for replacement.
9/18/2017 5:00:04 PM • Mitsubishi... • Answered on Sep 18, 2017
Ok the i got a problem the buttions for my monitor
mcdevito75 here, Thru the control panel, click start, the control panel, then display options, Brightness and volume. Most likely you"ll need another monitor as adjustments from your computer only are limited.
6/26/2010 11:28:05 PM • Mitsubishi... • Answered on Jun 26, 2010
Do not know what plug ins to attach to computer
It's very likely what you call the flat plug is the video cable. (Picture #1) below. The corresponding cable looks like (Picture #2). The other cable (A/C) by elimination plugs into an electrical outlet. Are you seeing a cable other then this one coming out of the back of monitor? d82bfa4.jpg697a779.jpg
11/29/2009 10:57:44 PM • Mitsubishi... • Answered on Nov 29, 2009
4answers
Monitor turns off automatically..
It's possible that the ACPI (Advanced Configuration and Power Management Interface) is not enabled in the bios. To access the bios either press F2 or DEL, depending on the motherboard(usually tells you on the initial boot screen), then look for a line that reads 'Power Management Setup' or similair and press ENTER. When into the menu check to see if ACPI is reading enabled, if not press the right arrow on your keyboard then either press PAGE UP or PAGE DOWN or + or - on the keyboard. Press 'ESC' then it will ask if you if you want to save changes, press'Y'. That should sort it.
12/30/2008 5:46:04 AM • Mitsubishi... • Answered on Dec 30, 2008
Computer monitor flickers
See Veriables & P/S Resistances.
7/2/2008 9:57:19 PM • Mitsubishi... • Answered on Jul 02, 2008
0answers
I have an issue of my car mitsubishi spacegear,,4m40 year 1994..why does A/T blinking at the dashboard??
It sounds like you are experiencing an issue with the automatic transmission (A/T) indicator light on your dashboard. The A/T indicator light is designed to alert you to problems with the transmission system. If the light is blinking, it may indicate that there is a problem with the transmission and it should be checked as soon as possible. There could be a number of reasons why the A/T indicator light is blinking on your Mitsubishi Spacegear. Some common causes include:
  1. Low transmission fluid level: If the transmission fluid level is low, it can cause the transmission to malfunction and the A/T indicator light to blink. Check the transmission fluid level and add more if necessary.
  2. Faulty transmission control module: The transmission control module is responsible for controlling the transmission. If it is not functioning properly, it can cause the A/T indicator light to blink.
  3. Wiring issues: If there are problems with the wiring in the transmission system, it can cause the A/T indicator light to blink.
I recommend having a mechanic diagnose the problem in order to determine the cause and recommend the appropriate repair. I hope this helps! Let me know if you have any other questions.
1/1/2023 11:52:49 PM • Mitsubishi... • Answered on Jan 01, 2023
Question about Mitsubishi D80
Mitsubishi D80not told how connectedNO PC toldno OS Told (windows or mac or what) XP to W8 is yes.no connections told.when did it last run googe, last week, last year or last decadereal model; this????CP-D80DW>> color printer?USB cable.? get the makers software , lost the CD of software ?windows XP and w7/8 is stated in your manualusing that?got front panel ALARM LED errors, page 20?read page 23, what to do before calling for help? do that?do the cleaning stepshttps://www.manualslib.com/manual/774805/Mitsubishi-Electric-Cp-D80dw.html?page=24&term=clean&selected=1#manualand up to w10 online support from maker. + OXS now.drivers seen here,the manual tells how to load that and connect USB last , never first, RTM read how to do that, and then test the printer with new ink.CP-D80DWhttps://mitsubishielectric-printing.com/en/downloads/drivers-tools
7/24/2022 8:39:22 PM • Mitsubishi... • Answered on Jul 24, 2022
I'm trying to find the engine number on my Mitsubishi magna wheres the location of it?
It is on the firewall on a metal plate. The firewall is the backwall of the car when you lift up your bonnet (hood). It should have your chassis number and engine number and paint code on it.
8/23/2019 9:03:35 PM • Mitsubishi... • Answered on Aug 23, 2019
How can i watch video through my sd card on mitsubishi nr-mz50 car dvd??
Mitsubishi Electric NR-MZ50 Car Navigation System $1800 !
WHAT CAR? and YEAR<, go to MFG. web sit and get the manual first, if LOST ! IT. What makes you think it can?> sure hope. WHA open glove box and RTM? yet, unstated car. car radio, head- in's/nAV are very dumbb(sic) as class of devices. they only allow a limited set of formats. you'r talking about movie file formats 100s, The movie file, formats to try are MP4 and MKV (most common) The manual Mz50. first. it will tell you what it supports, and no 2 car-heads work the same or have same limits, so that means RTM read the manual then do experiments. also some HEADs may have DRM rule limits. that car HEAD really is not a computer, so is off topic here. the MZ50 tuner can record to the SD card. why not just try it. find a small mp4 movie, and put it on the card, just 1 file and see if you can play it, but there are 100s of formats. talk to Mitsubishi dealer or try these https://fileinfo.com/filetypes/video It many do 1 or 2 but NEVER ALL formats.
7/1/2019 12:43:19 PM • Mitsubishi... • Answered on Jul 01, 2019
MITSUBISHI GLOVE COMPARTMENT LOCK
read the manual in the box, oops, can't down load it ? lost the key?
5/21/2019 6:42:49 PM • Mitsubishi... • Answered on May 21, 2019
Mitsubishi lancer 2.0 2009.shaking. I did wheel alignment & balancing and still the same. Took it for mechanic told the left shock had split oil. Advised to buy shock,tie rod ends & stabilizer links.
advised to buy [was those parts replaced ] and was damaged shock replaced in February or is it still damaged --your question is all over the place and confusing --------lets assume problem is now and alignment and balance was done recently bad shock -balljoints -upper or lower control arm bushings - tierods - steering rack- c/v axle --brakes any or all can cause shaking before throwing parts at it have the mechanic tell you reason part[s] need replacement and have them show you
11/6/2018 2:06:27 PM • Mitsubishi... • Answered on Nov 06, 2018
2answers
Getting speakers to work on Mitsubishi Medalion HD1080
get the latest drivers
11/15/2017 1:20:18 PM • Mitsubishi... • Answered on Nov 15, 2017
Mitsubishi Diamond Pro 91TXM 21" CRT Monitor Logo
10 questions posted
Top Mitsubishi Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
john h
ADMIN Andrew
ADMIN Andrew
Are you a Mitsubishi Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Diamond Mitsubishi
  • Diamond Mitsubishi
Most Popular Question
monitor turns off automatically
  • Computers & Internet
