20 Most Recent NEC MultiSync LCD1720M (Black) 17 in. Flat Panel LCD Monitor Questions & Answers
0answers
0answers
LCD computer monitor will not turn on, but just
Can you see a dim image when you view the screen at a sharp angle?
If so you have a backlight problem, the fault could be a faulty inverter that supplies high voltage to the CCFL lamp or the CCFL lamp could be faulty.
Check LCD Parts for parts, service and DIY info Usr this link :-
www.lcdparts.net
9/7/2009 12:52:36 AM • NEC MultiSync... • Answered on Sep 07, 2009
I CAN'T READ THE BLUE TEXT IN MY E MAILS
If Blue colors display properly in pictures or graphics check the display and size settings of your computer in relation to the size monitor.
If there is a problem with the blue color because of a problem with the monitor you might be able to compensate for it either with controls on the monitor or with the control software of your video card.
7/17/2009 2:27:41 PM • NEC MultiSync... • Answered on Jul 17, 2009
I have a NEC MultiSync
connector problems
3/26/2017 7:28:02 PM • NEC MultiSync... • Answered on Mar 26, 2017
0answers
No audio output
Some monitors do no come with built in speakers and a sound system much be purchased to have sound from pc.
11/6/2013 10:25:39 PM • NEC MultiSync... • Answered on Nov 06, 2013
2answers
Kds k917s monitor won't turn on green power light flashes on when plugged in
check the vga cable which get loose connection then the signal from pc not recognized.
12/25/2012 3:44:10 AM • NEC MultiSync... • Answered on Dec 25, 2012
0answers
I need a manual for NEC XM 3750
look on net for the manufacturers website and see if you can downlod it from their in PDF format
1/10/2012 9:32:04 PM • NEC MultiSync... • Answered on Jan 10, 2012
Nec projector me423w turning off randomly
Check the Eco Mode Page 38 and Standby Mode Page 37 settings in user manual. See also page 90 troubleshooting of user manual ME403U_manual_ENG.pdf (sharp-nec-displays.com)
1/1/2024 8:22:42 PM • NEC Computers &... • Answered on Jan 01, 2024
2answers
What software or cords do I need to get/run in order to get files to transfer to/from the NEC Mobilepro 770, or even get internet?
The NEC Mobilepro 770 is a legacy device that was released in the early 2000s and uses Windows CE as its operating system. Since the device is no longer supported, it may be challenging to find software and drivers that are compatible with modern operating systems like Windows 10. Here are some steps you can take to transfer files and connect to the internet:
  1. Get the necessary cables: You'll need a USB cable to connect the Mobilepro 770 to your Windows 10 PC. The cable should have a USB Type-A connector on one end and a mini-USB connector on the other.
  2. Install ActiveSync: ActiveSync is software that allows you to synchronize files between your Mobilepro 770 and your PC. Unfortunately, ActiveSync is no longer available for download from Microsoft, but you may be able to find an archived version of the software on the internet. Install ActiveSync on your Windows 10 PC and connect your Mobilepro 770 to your PC using the USB cable. If the device is recognized, you should be able to transfer files between the two devices.
  3. Connect to the internet: The Mobilepro 770 has a built-in Ethernet port that you can use to connect to a wired network. To connect to the internet, you'll need an Ethernet cable and a wired network connection. Plug one end of the Ethernet cable into the Mobilepro 770's Ethernet port and the other end into your router or modem. You should be able to browse the internet using the Mobilepro 770's built-in web browser.
  4. Install additional software: The Mobilepro 770 comes with a basic set of software, but you may want to install additional software to make the device more useful. You can download and install software from the internet, but make sure it's compatible with Windows CE and the Mobilepro 770.
Keep in mind that the Mobilepro 770 is a legacy device, and its performance and capabilities may be limited compared to modern devices. It's also possible that some of the software and drivers you need may no longer be available or supported.
10/7/2023 6:36:01 PM • NEC Computers &... • Answered on Oct 07, 2023
How to view files from old NEC versa 4050c. hard drive op-220-62005
They don't make them like that any more! The Service Manual lists it as a standard IDE drive. Your best bet is to take it to a local computer shop. They can remove the drive and add it to a test bench set up, then transfer all the data to a pen drive as the hard drive is only 2.1 Gb. https://www.manualslib.com/manual/366990/Nec-Versa-4000.html?page=42&term=hard+drive&selected=3#manual Or use the power supply from another old computer, as the connector plugs should be the same, 12 volt and 5 volt. Or get another on eBay NEC Versa 4050c 90mhz Pentium laptop off eBay for $25 shipped. It has a 2.1gb drive, 40mb of ram. It came with a docking station. https://www.google.com/search?q=NEC+versa+4050c https://www.google.com/search?q=nec+versa+4050c+transfer+data+to+pc ..
9/9/2023 7:32:18 PM • NEC Computers &... • Answered on Sep 09, 2023
2answers
I have an NEC Multisync LCD4610-BK that I can't get sound output from. I'm trying to use it with a roku device that is plugged in via HMDI to DVI converter. How can i get sound?
DVI video cables don't carry audio. Thus you need to use an audio extractor or converter instead of just an HDMI to DVI adapter cable. Try something like this: https://www.amazon.com/J-Tech-Digital-Extractor-Converter-JTDAT5CH/dp/B00BIQER0E/ref=psdc_280341_t1_B01MQYTUAK . Then connect the HDMI to DVI cable to the HDMI out of the converter. Then the audio out to one of the audio connections on the LCD4610-BK. Note: this converter requires you to get the extra HDMI and audio cables separately. Depending on your ROKU device, you might need an HDMI (F to M) adapter to ensure that you aren't blocking other things on the front of the converter. Then set the monitor to the appropriate video and audio inputs separately. I hope this helps. Cindy Wells
6/14/2023 6:41:32 PM • NEC Computers &... • Answered on Jun 14, 2023
How do I change the time on NEC Dterm Seriesi So far I have pressed feature 4, Feature 9 then #
There is a post here: https://sundance-communications.com/forum/ubbthreads.php/ubb/showflat/Number/242170/Searchpage/2/Main/42698/Words/time/Search/true/time-change-this-weekend#Post242170SV8100 and IPKII systemsFrom any display phoneWith the phone hung up to endCheers from Atcomhttps://atcomsystems.ca
4/18/2023 8:52:30 PM • NEC Computers &... • Answered on Apr 18, 2023
NEC MultiSync LCD1720M (Black) 17 in. Flat Panel LCD Monitor Logo
7 questions posted
Top NEC Computers & Internet Experts
ADMIN Eric
ADMIN Eric
Jim LeVerso - IT...
Jim LeVerso - IT...
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
MultiSync NEC
  • MultiSync NEC
Most Popular Question
lcd computer monitor will not turn but
  • Computers & Internet
