20 Most Recent
Sharp VL-H860U Camcorder Questions & Answers
I need to transfer my sharp VL h860 Hi 8 tapes to
You can get videos from this camera, or any analogue video source, into a computer, but you need more than just a cable. You have to play them into an analogue video interface port. These are available as expansion slot cards for a desktop PC, or as a USB plug-in interface (which is what you need for a laptop). The interface will come with drivers and probably software to digitise the video input and record it to a file. Lots of third party video editing software will also be able to accept the input from this kind of port. You don't need any "driver" related to the camera, it is just a video signal source. The connecting leads will be standard RCA signal plugs, like the ones you use to connect to a TV or VHS recorder. You probably already have a lead for this.
Once you have the video on the computer, you will need DVD "Authoring" and burning software, which will usually come as part of the same package. You can download such software for free from the internet- my first stop would be www.download.com.
Where can I find the PC Connect cable for a Sharp Camcorder Model VL-SD2OU
You may be able to find the PC Connect cable for your Sharp Camcorder Model VL-SD2OU at an electronics store or online retailer that specializes in video and camera equipment. You can also try contacting Sharp directly to see if they have the cable in stock or if they can suggest a retailer that carries it. Alternatively, you may be able to use a generic USB cable to connect your camcorder to your computer, depending on the capabilities of your camcorder and computer.
Keep in mind that you may need to install any necessary software or drivers on your computer before you will be able to access the video files on your camcorder
How can I find a US repair shop to have my Sharp Hi-8 camcorder repaired? A
Newton Ellis & Co. repair most makes and models of camcorders and video cameras. If you are having a problem with your camcorder or video camera then bring or send it in for a free estimate, we can usually give you an idea of what is wrong with it and an idea of the cost. If you can't get in to our shop then give us a call and we will try to help you over the phone or just send an email, see the 'Contact Us' page. We do try to make the repairs as cost effective as possible so if you have an older model then we will try our best to keep the cost down if at all possible.
E commerce Software ecommerce software solution & Online Shopping Cart for small business
https://www.tritansolutions.com/Home/Ecommerce-Solutions
