20 Most Recent Halonet 99-05 BMW E46 3-SERIES 2/4/5DR, CONVERTIBLE: 318i, 318is, 318ti, 320i, 323i, Questions & Answers
fuel pump may be the problem or at least a leak someplace it should hold pressure when shut off . try replacing the fuel filter first .
Halonet 99-05... | Answered on May 13, 2016
I think brake proportional Valve (or Brake pressure regulator) which usually a part of Master cylinder is suspicious.
It regulates pressure to Front and Rear brake line.
If I were you, I try to draw air from Master-cylinder side (not Caliper side).
(Bleed from connector between Master-cylinder and pipe, same way as caliper. someone keep pushing brake then you lose connector then tight. Don't forget to put towel under master cylinder to catch brake fluid)
If air trapped in Proportional valve (pressure regulator), pressure won't relay to rear brake line but only front side.
Front has two separate line from master cylinder (right and left) but rear goes in one line from master cylinder then separate at rear.
Did you noticed both rear brake dragged when it's hot day ?
Because when air get hot, air expand and pushes to caliper and drag but not respond to your pedal.
(calipers don't respond when you push pedal, but it's pushes calipers by itself even you are not pushing pedal, when it's hot because air expand)
Sometimes, seal get old and lose pressure for only one side (front or rear).
if this happened after you did brake job, or you notice your brake was vapor locked (too much brake on hot day then brake fluid boiled), maybe air bleed and whole fluid change may solve.
if you didn't have any unusual activity but it gradually losing pressure to rear, I suspect master cylinder (proportional valve seal).
Sorry I don't have exact e46 master cylinder diagram but basic diagram, hope you can understand what I am talking about.
Picture shows "leak" but this case "Air" in somewhere in pink.
or lose seal on rear piston.
Halonet 99-05... | Answered on Dec 02, 2015
Try to spray the commercial available mist to lower surface tension in order to avoid build-up of condensed water
Scuba Diving &... | Answered on Nov 02, 2018
who knows what is a sheet mask? seems this is not a repair question on a repair forum
Scuba Diving &... | Answered on Jul 04, 2018
If I'm reading this right you have an octopus which is a second emergency regulator for your buddy if he is in trouble. Where the original regulator hooks to the valve that goes on your tank ther should be a blank with a screw in it . This is where the octopus screws in . You will have a rubber o ring in side. Put it on the end of the threads from the octopus hose and insert it into the hole the screw once occupied.. The screw is just there to fill the blanks hole and can be thrown out.
Scuba Diving &... | Answered on Apr 24, 2018
get that from <a> here </a>masskarafestivals.com/masks/
Scuba Diving &... | Answered on Nov 11, 2017
you can search online and u shld find it
Scuba Diving &... | Answered on Sep 27, 2017
Hey Candy,
I am sorry to tell you that NO ONE on fixya can help you,, we have NO WAY to find out any information of that type,, PLEASE contact the carrier AND the company that sent you the package... and your credit card company..(if that's how you paid for it!) ..and from now on - ALWAYS get something sent with SIGNATURE REQUIRED!!
Scuba Diving &... | Answered on Sep 17, 2017
Halonet 99-05 BMW E46 3-SERIES 2/4/5DR, CONVERTIBLE: 318i, 318is, 318ti, 320i, 323i, Logo
6 questions posted
Top Halonet Scuba Diving & Snorkeling Experts
Tom Chichester
Bill Boyd
Marvin
Marvin
Are you a Halonet Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
View Most Popular
  • Halonet Scuba Diving & Snorkeling
Most Popular Question
all wifes e46 318i doesn t want start
  • Scuba Diving & Snorkeling
