20 Most Recent RCA CC6373 Camcorder Questions & Answers
manual
CC6373 Camcorder Manual
RCA Video CamerasUploaded on Sep 22, 2013
RCA camcorder stuck in safeguard
rca stuck in safe mode , how to get it out.
10/13/2012 10:49:30 PM • RCA CC6373... • Answered on Oct 13, 2012
My camcorder is stuck in safe mode and I can't
Have you attempted to remove the battery and power from the camera? Usually when a camera is stuck in safe mode if you remove all power from the device and wait a while (I would say 15 minutes should do the trick) it will clear the safe mode and you should be off and running.
6/27/2011 2:49:02 PM • RCA CC6373... • Answered on Jun 27, 2011
RCA camcorder model # CC6363
http://www.google.co.nz/search?sourceid=chrome&ie=UTF-8&q=RCA+camcorder+model+%23+CC6363+is+stuck+in+safe+mode+fix
Hi at the above link, you will find a myriad of people with a problem exactly the same as yours, it is a real headache, with NO real, well DIY fix, sorry, it appears that RCA will repair it for a price, so maybe it would be simply best to bite the bullet, and take it to a professional RCA servicing center, but ONLY ask for a "Quote". Now when you get this information, then you can make up your mind as to what to do, repair or replace?
As an aside here, and it is mentioned in that link i give you above, that this problem is a "Known About Issue" and in some countries they have been made to repair this issue FREE of charge to customers...
I actually haven't come across this exact type of problem with this exact type of camcorder, however, in my shop, I have seen similar repairs etc, and they can cost upwards of $200.00, so make sure you always get that quote. Further, there are a few postulated "Fixes" in that site given too, you can not do any real harm in trying any or all of them, especially the one about cleaning the "Heads & tape transport path" as described, this may just work, as may the Battery Removal/Replacement ... so good luck.
6/27/2011 8:24:50 AM • RCA CC6373... • Answered on Jun 27, 2011
0answers
My rca #cc6263 camcorder for some reason keeps
Hi.
Safe mode will start when a fault gets detected by camcorder control board.
If there is no fault, and the safe mode was triggered because of a temporary problem, then the camcorder will reset simply by removing battery for one minute.
If the Safe mode does not clear after removing and putting back the battery, and you get an error code, then there is an internal fault.
In your case E02 is traction error. This often happens because of mechanical problems in the tape player/recorder drive unit inside the camcorder.
You can try tapping the side of the camcorder with you hand, with the tape inside. Try also playing with Play, Rew. and FF. buttons, in some case that will unlock an E02 error.
If that does not happen, then there is a mechanical failure. In that case the camcorder must be taken apart and repaired by a technician.
Best regards.
11/22/2009 5:45:49 PM • RCA CC6373... • Answered on Nov 22, 2009
2answers
RCA 200X Auto Shot camcorder instruction manual
need instruction manual
12/11/2008 1:41:18 PM • RCA CC6373... • Answered on Dec 11, 2008
RCA CC604 VHCS Camcorder. My old camcorder won't record?
Question edited into written English with punctuation. The lens isn't black, the viewfinder is black. Connect it to a television or computer and see if playback and live recording is working. In that way you know the optics and the electronics are working. The viewfinder is a small LCD display screen with a magnifying glass in front of it. Take it to your local camera shop, they will know someone that still repairs these camcorders. I was hoping to find a free PDF manual as I wondered if there is a switch or a setting to turn OFF the viewfinder? https://www.google.com/search?q=RCA+CC604+VHCS+Camcorder+manual ..
2/11/2023 11:54:21 PM • RCA Video... • Answered on Feb 11, 2023
2answers
RCA CC433 will not record or play back tapes
Hi, You can first check for any debris in the video tape player and double check that no settings are stopping the tape from playing (ie a stuck rewind button) . Otherwise, please use the services of geeksquad/bestbuy to refurbish your vcr player. You might also check out BandH (?) video to see if they can refurbish your video tape player. Thank you.
11/18/2022 6:23:14 AM • RCA Video... • Answered on Nov 18, 2022
Vintage RCA Solid State Image Sensor VHS camcorder (Model Number CC275) wont record anything, or play back video. I’ve been putting in only new tapes with the tab intact, and every One simply refuses to record. I tried playing back an old vhs tape from like 30 years ago and while it did rewind, it didn’t play inside the camera. Does anyone know how I might be able to remedy This? Thank you in advance
I don't know anything about the vhs camera - other than they produce superior quality, when they work ok. It would be reasonable to assume the tape transport mechanism would be the same as in a vhs video recorder. I remember an engineer telling me there is a post or protrusion containing a light source and sensor that sometimes fails. The purpose of this is to detect a cassette has been properly loaded into the machine and if it isn't working the machine won't work or only partly work. I think the camera is worth saving but I strongly suggest such specialist equipment should be entrusted to a suitably experienced professional specialist.
3/2/2020 1:38:35 AM • RCA Video... • Answered on Mar 02, 2020
Looking for a RCA pro 8 camcorder Manaul
Do you have a model number? I found a manual for the RCA Pro8, Pro807, from Voxx here: https://voxxintl.zendesk.com/hc/en-us/articles/225487888-Information-and-Owner-s-Manual-for-the-RCA-PRO8-Model-PRO807-Camcorder . The direct link to this manual appeared as https://sc.voxxintl.com/docs/common/PRO807/PRO807_OM.pdf in my browser history. I hope this helps. Cindy Wells
9/9/2018 9:57:07 PM • RCA Video... • Answered on Sep 09, 2018
RCA CC9360 Steady Pix camcorder has grinding sound, jerky playbac
I am sorry to say that it appears you may have answered your own question, the "hundreds of hours" is the clue. Consider the possibility that your camera is worn out. Sorry.
12/12/2017 7:08:56 PM • RCA Video... • Answered on Dec 12, 2017
0answers
Rca camera
Be the first to answer 11/29/2017 12:04:56 AM • RCA Video... • Posted on Nov 29, 2017Be the first to answer
I have an RCA small wonder, does not load on my PC
It appears to have a built-in USB connector, use that.
11/10/2017 11:13:33 PM • RCA Video... • Answered on Nov 10, 2017
My cc275 vhs rca comcoder on camera will not focus are stay on rec for 2 second
I understand you have a problem. What is not clear from your description, however, is the actual nature of the problem. Please can you state it more clearly. Thank you.
6/15/2017 10:00:17 AM • RCA Video... • Answered on Jun 15, 2017
Cc275 vhs camcorder vhs rca rec will not say on 3min.
Won't say what ? Hello ? Goodbye ?
6/9/2017 8:35:38 AM • RCA Video... • Answered on Jun 09, 2017
0answers
Need a manual for rca camera
You can download a manual for almost any equipment by Googling the make and model followed by the word Manual, then follow the appropriate link(s).
1/2/2017 10:43:55 PM • RCA Video... • Answered on Jan 02, 2017
RCA CC6373 Camcorder Logo
19 questions posted
Top RCA Video Cameras Experts
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
ADMIN Eric
ADMIN Eric
Are you a RCA Video Camera Expert? Answer questions, earn points and help others
View Most Popular
RCA Video Cameras
  • RCA Video Cameras
Most Popular Question
rca 200x auto shot camcorder instruction
  • Video Cameras
