20 Most Recent
Sharp Viewcam VL-NZ150U Mini DV Digital Camcorder Questions & Answers
MEMORY CARD ERROR
Camera is not recognizing any memory card. The issue is with the camera electronics and not the cards.
What can I find a usb cord for this camcorder?
Hello
OK, firstly, the DATA USB cable you need for this specific model is an USB 2 Mini-B 5pin cable.
You will be able to buy this specific cable at any computer, camera or electric store near you for about $5 - $10.
I really hope this can be of help.
Let me know if you need any further assistance.
Kind regards
Andrea
Sharp VL-DC5
You should have the driver on the cdrom that came with the cam, as it may well be hidden within the software if you have'nt installed it.
But if the problem continues, uninstal the current drivers in add/remove programmes and re install and add your cam to a different usb port than before, although i would of thought firewire connection would be more suitable for speedier transfers.
Where can I find the PC Connect cable for a Sharp Camcorder Model VL-SD2OU
You may be able to find the PC Connect cable for your Sharp Camcorder Model VL-SD2OU at an electronics store or online retailer that specializes in video and camera equipment. You can also try contacting Sharp directly to see if they have the cable in stock or if they can suggest a retailer that carries it. Alternatively, you may be able to use a generic USB cable to connect your camcorder to your computer, depending on the capabilities of your camcorder and computer.
Keep in mind that you may need to install any necessary software or drivers on your computer before you will be able to access the video files on your camcorder
How can I find a US repair shop to have my Sharp Hi-8 camcorder repaired? A
Newton Ellis & Co. repair most makes and models of camcorders and video cameras. If you are having a problem with your camcorder or video camera then bring or send it in for a free estimate, we can usually give you an idea of what is wrong with it and an idea of the cost. If you can't get in to our shop then give us a call and we will try to help you over the phone or just send an email, see the 'Contact Us' page. We do try to make the repairs as cost effective as possible so if you have an older model then we will try our best to keep the cost down if at all possible.
E commerce Software ecommerce software solution & Online Shopping Cart for small business
https://www.tritansolutions.com/Home/Ecommerce-Solutions
