20 Most Recent Northgate EZ18A (Silver) 18 in. Flat Panel LCD Monitor Questions & Answers
Try changing the CMOS battery, and see if the problems go away.
Northgate... | Answered on Aug 07, 2014
You should have mentioned your Operating System, but I would email or call Newegg, and ask them. http://help.newegg.com/app/home/site/US#ContactUsTab
Northgate... | Answered on Jul 30, 2014
Please don't turn it back on. Unplug your computer from the wall and examine the wall socket for blackened or burned sections. It is likely that dust has caused a short in your computer. Sadly, most times this means that you are going to need a new computer or at the very least, some new parts. Take it to a reputable computer repair shop near you and have them test the power supply and other components to see what is salvageable of your computer. With any luck, your hard drive contents MAY have survived but there is no guarantee.
Northgate... | Answered on Mar 27, 2014
"40drhol"? If you are re-installing the OS, when you re-install it will ask if you want to format. If the HDD is not the Primary HDD in your computer. a spare HDD, If the HDD is compatible with your computer interface you can install as a slave/second/primary, depending on the interface/pin outs, or load a different OS on it if you wish and have a Dual-Boot. If it's a second drive in your computer, Open Start Menu, Computer, Select the HDD, just right click and format ,select File System.
Northgate... | Answered on Feb 15, 2013
You need to install the driver of your printer that works with the operating system of your northgate computer. The driver is in the CD/DVD that came with your printer.
After installing everything, you can add RadarSync to your computer to optimize your computer's driver (eg. keeping them updated to avoid from some problems, and running automatic updates so that you can avoid from the headaches of doing the updates manually).
I hope this helps.
If you need more info, please let me know.
Carlo
Northgate... | Answered on Jan 23, 2013
You can download the HP printer drivers from their support WEB site. Please click on this link and select your model printer to download :- http://welcome.hp.com/country/us/en/support.html
You may have to use the XP drivers . there may not be drivers developed yet for the Windows 7.
The manufacturer is the one who supplies compatible drivers to run with the operating system.
Northgate... | Answered on Jun 21, 2011
Go to the control panel and find the system folder then find the device manager then find your sound card and you can load the driver from there. Also make sure your sound is not muted.
Northgate... | Answered on Apr 20, 2011
During the boot process you will see on the screen to press delete to enter setup
Press and hold delete during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart then
once you have your computer running try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive then you might test all leads that are attached from your ((motherboard to your hard drive)) or just replace them there probably old and faulty
hope this helps
Northgate... | Answered on Mar 27, 2011
Download pc login and burn under nerro burning option ,and restart pc pres F2/F10/Dell boot from cd Insert bootable pc login and it automtically reset your password ,
http://www.windowsreinstall.com/articles/bios/
http://sourceforge.net/projects/pcloginnow/
Hope this helps.
If you are helped you can rate on the 4 thumbs and leave a short comment,because,
this is the free side and I can get the chance, to help people like you .
Thanks for using fixya .
Northgate... | Answered on Mar 11, 2011
Does this problem came all of a sudden? Do you hear sounds before? Check the icon with the speaker (or something like this) at the lower right end of the taskbar. Is it marked as forbidden? Click on it and enable sounds.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Northgate... | Answered on Sep 09, 2010
Some laptop keyboards have small "tabs" on the edge closest to the LCD screen, and those tabs fit "under" something metal,
in order to hold the keyboard in-place. Gently "work" that area, to get those tabs to move "above" (instead of "under"), to release the keyboard.
Northgate... | Answered on Aug 22, 2010
Hi
Thank you for your query
Please do the following steps to narrow the problem down
1) Switch on the laptop
2) Once switched there may be a meeage that says press del or F12 to enter setup, if not try the del key or F12
3) This will being you into the bios screen, once in there let the laptop run, if the laptop keeps cutting out in tis mode, you will have a overheating issue
If it is overheating then try cleaning out the vent where the hot air comes out from, if that doesnt looked block then it looks like the Heat sink (the fan that cools the CPU down) is faulty and will need to replaced.
If however it does not cut out then you have a sftware issue and i would recommned a clean install
Hope this helps
If this has been useful please leave positive feedback/vote
Northgate... | Answered on Feb 12, 2010
Northgate EZ18A (Silver) 18 in. Flat Panel LCD Monitor Logo
3 questions posted
Top Northgate Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
Håkan Sterner
Carlo Barzo
Carlo Barzo
Are you a Northgate Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Northgate Computers & Internet
Most Popular Question
lost power cord buy new one
  • Computers & Internet
