20 Most Recent
RCA CC617 VHS-C Analog Camcorder Questions & Answers
Picture rolls on playback
Possible causes: the sync signal head is not recording, there is a mismatch between the capstan motor speed and the video head speed, or one of the sync circuits has a fault. Typically, if the picture rolls up or down, it's a vertical sync problem. A horizontal sync fault or tracking mismatch will cause the picture to tear sideways.
Try cleaning the sync head (one of two heads separate from the video head drum; the other is the audio track head), but don't be surprised if doesn't solve the problem.
RCA CC617
probably the lcd screen is broken (the one that you can see through the veiw finder) if this is the case it is not reasonably fixable. Otherwise it may be a connection that is broken and it is not getting any feed. If you give it a little tap and it comes to life breifly, this is probably the case. You can take it to a small electronics repair shop and they will let you know if its worth fixing or just using as is.
RCA CC604 VHCS Camcorder. My old camcorder won't record?
Question edited into written English with punctuation.
The lens isn't black, the viewfinder is black. Connect it to a television or computer and see if playback and live recording is working. In that way you know the optics and the electronics are working. The viewfinder is a small LCD display screen with a magnifying glass in front of it. Take it to your local camera shop, they will know someone that still repairs these camcorders.
I was hoping to find a free PDF manual as I wondered if there is a switch or a setting to turn OFF the viewfinder?
https://www.google.com/search?q=RCA+CC604+VHCS+Camcorder+manual
2/11/2023 11:54:21 PM •
RCA Video...
Answered
on Feb 11, 2023
RCA CC433 will not record or play back tapes
You can first check for any debris in the video tape player and double check that no settings are stopping the tape from playing (ie a stuck rewind button) . Otherwise, please use the services of geeksquad/bestbuy to refurbish your vcr player. You might also check out BandH (?) video to see if they can refurbish your video tape player.
Thank you.
11/18/2022 6:23:14 AM •
RCA Video...
Answered
on Nov 18, 2022
Need a manual for rca camera
You can download a manual for almost any equipment by Googling the make and model followed by the word Manual, then follow the appropriate link(s).
1/2/2017 10:43:55 PM •
RCA Video...
Answered
on Jan 02, 2017
