20 Most Recent
RCA CC4252 Camcorder Questions & Answers
RCA Camcorder
It's been a while since I worked on the RCA full size camcorders as well. It sounds as though the load motor is "jogging" because the mode switch is not in time with the mechanism. I think there are timing marks on all the cams and gears in the unit and an indicator arrow on the mode switch.
Set the mechanism to the "stop" mode and align the main cam index mark to the load motor drive cam, be sure the mode switch arrow points to the load motor drive gear "hole", this tells the micro the unit is in "stop" mode.
Good Luck
Joe Weibel
customelectronics.org
The viewfinder is dead
Thats an oldie but still a goodie.. this camcorder was made by Hitachi for RCA and its doubtfull that theres any parts
available for it. You are probably gonna have to look around for someone with old camcorders laying around and swap out the veiwfinder . these units are also famous for the belts to go bad in them. if you take this unit to a servicer they probably have a flat rate as I've seen online under camcorder repairs unless you think you can do it your self?? Good Luck
PS If I get a good look at the veiwfinder and if theres a plug or is it hard wired I may have one as I got several camcorders around the place i use for opsolete parts.
RCA CC604 VHCS Camcorder. My old camcorder won't record?
Question edited into written English with punctuation.
The lens isn't black, the viewfinder is black. Connect it to a television or computer and see if playback and live recording is working. In that way you know the optics and the electronics are working. The viewfinder is a small LCD display screen with a magnifying glass in front of it. Take it to your local camera shop, they will know someone that still repairs these camcorders.
I was hoping to find a free PDF manual as I wondered if there is a switch or a setting to turn OFF the viewfinder?
https://www.google.com/search?q=RCA+CC604+VHCS+Camcorder+manual
2/11/2023 11:54:21 PM •
RCA Video...
Answered
on Feb 11, 2023
RCA CC433 will not record or play back tapes
You can first check for any debris in the video tape player and double check that no settings are stopping the tape from playing (ie a stuck rewind button) . Otherwise, please use the services of geeksquad/bestbuy to refurbish your vcr player. You might also check out BandH (?) video to see if they can refurbish your video tape player.
Thank you.
11/18/2022 6:23:14 AM •
RCA Video...
Answered
on Nov 18, 2022
Need a manual for rca camera
You can download a manual for almost any equipment by Googling the make and model followed by the word Manual, then follow the appropriate link(s).
1/2/2017 10:43:55 PM •
RCA Video...
Answered
on Jan 02, 2017
