20 Most Recent Acer AL1912 19" LCD Monitor Questions & Answers
I have an Acer al1912
tad older post but not too old, and ignored.it's an old monitor lucky you it works at all,after all most are dead now, 99%15 years old today.if the OSD is dead under 10second from, power onthe Montors CCFL tubes are dead.the fail these ways1: dead for ever.2: work intermitantly (you)3:Strobes.(means flashing like in a DISCO)4: only 1/2 screen dead, (2 tube displays)5; turn yellow, for white6: dim, for ver.never seen any 15 year old CCFL screens good.not me unless parked on self for 10 years.the clue is on last page, in your manual, the word "mercury Hg toxic, it's there, means CCLF tubes here)the cure is 2010 or newer monitors with LED back lampsdo that now, end the pain of #1 soon to happen.
12/14/2018 6:01:23 PM • Acer AL1912 19"... • Answered on Dec 14, 2018
VGA To HDMI ?
Here you go. Some very inexpensive and they work well. https://www.amazon.ca/s/ref=nb_sb_ss_i_2_11?url=search-alias%3Delectronics&field-keywords=vga+to+hdmi+adapter&sprefix=vga+to+hdmi%2Celectronics%2C145&crid=1HJZTZOV9K2UA
10/8/2017 6:32:12 PM • Acer AL1912 19"... • Answered on Oct 08, 2017
0answers
2answers
Al1912 monitor with grey volume
Normally problem is defective switches rather then mainboard. If volume + is coming on chances are that the switch is mechanically stuck or electrically leaky. If you are technically able I can guide you further. Regards. Samir
9/18/2015 3:54:59 PM • Acer AL1912 19"... • Answered on Sep 18, 2015
I have an acer AL1912 and a (auto config please wait) gray box keeps popping up,how do i stop it
If it gives you message about the resolution, set the computer to use native resolution of the monitor. You can change the resolution by right clicking on desktop and choosing "screen resolution".
6/4/2014 12:08:42 PM • Acer AL1912 19"... • Answered on Jun 04, 2014
0answers
Menu keeps popping up
Never a good idea to clean with any spray cleaner. The cleaner does get down in the button bar and cause corrosion and shorting along ribbon cable. Use screen wipes for computer monitors only on TV's and any type of monitors. You can remove the back of the case. And remove the button board and clean with a cue tip and alcohol along ribbon cable.
9/16/2013 12:43:45 AM • Acer AL1912 19"... • Answered on Sep 16, 2013
0answers
4answers
Need to know how to Disassemble AL1912 19" LCD Monitor
The ones I take apart have a snap on front bezel.
gently pry at the lcd edge with fingers in center left or right to get it to bow , dont damage the lcd with too much pressure.
it will start to separate ,put a plastic knife or such in the outside crack and work your way around once you have one side the rest will be easier. you have to bow the inside edge out(away from the lcd) because of the plastic clips.
luck.
4/26/2013 12:00:00 AM • Acer AL1912 19"... • Answered on Apr 26, 2013
2answers
My monitor pops up a stupid dialog box every 2
most common problem is a faulty regulator inside the unit..have it checked.
4/19/2011 4:19:01 AM • Acer AL1912 19"... • Answered on Apr 19, 2011
I am having trouble exporting
you will do, cd writers will not write to a dvd. you can either replace your cd writer with a dvd-rw drive (dvd-rw drives will also write to cd) or you can get an external usb dvd drive.
4/5/2011 9:23:11 PM • Acer AL1912 19"... • Answered on Apr 05, 2011
I use Acer AL1912 19inch
Sounds like the monitor is dying, if it starts to die more and more often you will likely have to replace your monitor before it goes completely out. There are not many ways for a user to repair a monitor, unless the problem is with the computer, which you could test by connecting a different monitor to the computer for a while (if available). Hope this helps!
3/15/2011 5:02:27 AM • Acer AL1912 19"... • Answered on Mar 15, 2011
I boot up the PC,
You can perform a test by plugging it into another PC/laptop to see if you can get the display. If it doesn't work there, you most likely need to replace/repair your screen. If it does, then it means that there is a problem with your PC's video card.
3/4/2011 1:52:44 AM • Acer AL1912 19"... • Answered on Mar 04, 2011
I get 1 second of picture after switch on then
Look for bad caps with domed tops, very common problem with all brands of LCD monitors.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on: Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/ Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide: http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide http://www.fixya.com/support/r7406380-tv_training_manuals Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series. Please leave rating if it helps.
2/11/2011 6:38:00 PM • Acer AL1912 19"... • Answered on Feb 11, 2011
My acer monitor is under a year old,and now when u
Hello. It is possible that one of the lamps that illuminate the screen is damaged, or may be .. something else. must be brought into service.
2/3/2011 6:57:48 PM • Acer AL1912 19"... • Answered on Feb 03, 2011
Acer AL1912 19" LCD Monitor Logo
97 questions posted
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
AL Acer
  • AL Acer
Most Popular Question
when turn computer screen just turns
  • Computers & Internet
