20 Most Recent
Acer Professional P211 21" CRT Monitor Questions & Answers
Acer monitor lcd problem
Try the monitor with another known working computer, If ng there also, then have unit repaired under Acer warranty.
8/31/2017 12:45:52 PM •
Acer...
Answered
on Aug 31, 2017
New netbook cannot see full screen
This is an issue with netbooks. 1. Make sure you have your screen resolution set with the highest numbers available (most dots per inch). (Much > 600x800.)2. Rotate the screen temporarily by using graphic options. OR IF you have Windows 7:Change the Display from "Medium" to "Small" setting. It's fine to change it back to medium when finished with the tall window, but remember how to find the setting. You'll need it again.Dawn C. Weikle, CNESouthportPC.com
12/23/2011 3:49:32 AM •
Acer...
Answered
on Dec 23, 2011
New netbook unable to see whole screen
I was having that problem as well on my msi wind netbook. Turned out that the default DPI setting was on large. After changing it to normal it fixed it. This is what I did, perhaps it will work for you. Good luck.
- Right-click somewhere on your desktop (not on an icon) and select properties.
- Click on the Setting tab and once there click advanced.
- You will see DPI setting, change that to Normal size (96 DPI) and then click apply
- Now restart your computer for the changes to fully take effect.
12/23/2011 3:41:33 AM •
Acer...
Answered
on Dec 23, 2011
The screen is pink tinted
A pink (or any tinted) screen is usually an indicator of one of two things:
1. The cable going from the video card to the monitor is loose. Try adjusting the cable and see if the picture changes. Put pressure in all directions slowly to see if it clears up. If it does, you should change your monitor cable.
2. One or more of your CRT "guns" or "rays" is malfunctioning, causing the red gun to be too strong, or causing the green or blue to be too weak. This is difficult to fix... time for a new monitor. Sometimes you can get a little more life out if by smacking the monitor on the side.
5/13/2009 8:13:07 PM •
Acer...
Answered
on May 13, 2009
Not working with dell computer
you need a Dvi to vga adaptor available at office Depot or virtually any electronics store you can even try walgreenes late night
12/10/2008 12:58:31 AM •
Acer...
Answered
on Dec 10, 2008
Acer P221W 20in blacking out
check your graphics card wait 20 minutes or more see what comes up i recently had that or if u try everything eg replacing everything and it still don t work try rebooting the computer with the recovery disc which means it will wipe out everything programs everything.
11/11/2008 5:21:25 PM •
Acer...
Answered
on Nov 11, 2008
Acer monitor lcd
no signal means there is no communication between your monitor and your system unit.check and be sure your monitor signal cable is firmly connected,if nothing happens, try the monitor on your friend's system.if no change then try and replace the monitor signal cable,
eyo7
[email protected]
2/28/2007 12:15:27 PM •
Acer...
Answered
on Feb 28, 2007
Automatic Full Screen View
You should be able to hit escape and options should appear, or rt click on the screen and options should be there as well. Have you tried these??
2/26/2007 6:34:18 PM •
Acer...
Answered
on Feb 26, 2007
Mpowering technology pop up
Couldn't get rid of mpowereing technology pop up. Tried every solution offered by the internet. Finally I noticed when I powered up my computer the pop up showed up even before the computer loaded anything. I turned off the power to the monitor and powered it back up an viola, pop up gone. The Acer monitor had generated the pop up.
My Acer X1110 switches off as soon as blue light comes on?
it needs service, and service manuals are hard to find on anything by the likes of ACER.
this projector worked for 12 long years, did you own it 12 or bought a bad projector, no history told as I can buy dead projectors all day long. and hard nut problems even hacking done.
Acer X1110 data projector Standard throw projector..
did you know most projectors have serious grade protective devices inside??? (tamper and overheating are 2)
did you read owners manual page 32 yet, errors.
LED codes.?
there are 4 LED, and all 4 matter, projector turned (ON) (not one =1)
also in pairs glowing and also if blinking or not, so read page 32
it tells all that.
my guess is overheat failures, even cold, due fan slow or packed in lint after 12 years of use and no service done,.
https://manualzz.com/doc/49497108/acer-x1110-user-manual
some have dust filtler
a shop first cleans is out first, and check fan RPM with and LED tachometer.
this is all SOP.
''e'' button :acer empowering technology
That button can be set using the utility on your programs list
It maybe that you accidentally turned it off or set it to do some other task.
Start there first before re-installing the program that sets it.
That is on one of the cds that should have come with it and can be installed by itself.
