20 Most Recent
AOC 5 En 15" CRT Monitor Questions & Answers
The screen turns blackout then after a seconds it
The problem is the picture board on your monitor, the picture board on the monitor is malfunction, that is why the screen goes off after few seconds and turn back on.
If the problem is a regular one, i will advice you replace the picture board on your monitor to fix the problem.
Take care.
All led is blinking when
first remove the cover of your computer after switching off the system and removing the power plug the power the system and see whether the processor fan is working if not power off the system and remove the 24 pin connector from the smps to the motherboard and short the green and black pin of the conector from the smps and see the smps fan is working if not replace the smps if working then remove the memory from the slot and clean them or change the memory to which match the dimm slot an connect the connector and switch on the computer
No display
According to the model type, it has likely reached the end of its service life. It would cost a great deal more to have it repaired than to replace it. Here is an example of an inexpensive alternative in the new market ( http://www.walmart.com/ip/Acer-ET.LBF09.030/5013901 )and there are thousands of used lcd monitors available from places like Ebay.
Color problem
try to press the recall botton is it works then good for you...
If not then try a degausser tool.
if it still have the same problem after using a degausser tool, then there might be some parts of the monitor which is defective..
Need schematic diagram for AOC 5 En model (white
my AOC crt monitor 5En model has this problem. it has over width the compress button (<> ) is no longer functioning what particular component should i check or adjust inside the circuit? please i need ur help..
No power. already checked power cable its okay.
Then the issue is inside the monitor itself. If this is a big CRT monitor I would NOT recommend working on it yourself as it is basically one big capacitor with a bad attitude, you may see if there are any monitor repair technicians in your area. But you may be better of just replacing it as they are very inexpensive now adays.
AOC color monitor model 5En...during
actually if u repair an aoc monitor alone without getting connected to cpu once u switch on the monitor all led's will lit on ( green light ) it will remain on situation until u connect the vga connector to cpu that's the time led's will lit off and only the power led will remain in green condition.some aoc 5en once u power on power led is in green condition and if not connected to cpu it will be in orange condition.hope u get some idea but i am not sure if it will work with ur monitor. but as long as LEDs lit on i think no problem with ur monitor.
AOC color monitor 15in. 5En model.
u try to reorient ur vga connection it might be a loose connection between ur monitor and ur cpu otherwise ur vga cable is defective...
My Monitor turns off and on. I can here the relay
I think it's the refresh rate.
In
XP:
Right-click, properties on the desktop
Select settings tab
Hit the advanced
button
Select the monitor tab
hit the box
(hide modes that this monitor cannot display)
Select a new
screen refresh rate
hit ok twice.
AOC 15" CRT
just change the botton switch.... with a new one...
WHITE SCREEN
first make sure its not the monitor... connect bad one straight to the video card and see if u get video if so then check, control panel / display / settings, are you still multiple monitor mode? try and identify also
